Question about Dishwashers
I have a Sears motion detecting control console #53688 motion detected and the button to open the door does not work .The green light just blinks, what is the problem?
  • 3 Answers
SOURCE: xbox 360 controller won't connect to console
If your controller is not assigned a position, and pressing the sync buttons on both the console and the controller don't fix it (i.e. they both spin for a bit, but then the console's lights turn off and the controller's return to a pulsing pattern), the the problem is actually likely to be your TV, believe it or not. The issue is HDMI -- it's a secure connection between the Xbox 360 and the TV, and if there's an issue with that connection, the Xbox won't even be able to turn on since it'll be unaware of the TV's resolution, color capabilities, etc. Try turning off the TV and then turning off the Xbox. Keep the TV off and turn the Xbox console back on. You'll see the same behavior; but now turn the TV back on and you should see the controller get assigned a position. As soon as the Xbox is aware of what it's connected to via HDMI, things start to work again.
Posted on Feb 23, 2009
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: The wall mount control for my sears/craftsman
Press and hold the button with the lock icon for 3 seconds. This will stop the blinking and your remotes should work.
Posted on Nov 11, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door don't open
On the wall control press and hold the button with the lock icon for 3 seconds. The blinking should stop and your remotes will once again work.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears garage door opener. The motion
The light will stay on as long as you are in the garage and it detects body heat. If you leave the garage the light should turn off.
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
