Question about Tecumseh Heavy Machinery
What size spark plug for wood chipper - Tecumseh Heavy Machinery
  • 83 Answers
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: i have a brush master chipper was working but has
look at the magnita the round **** under the coil you make just have to sand it with a fine sand paper and maybe the under side of the coil
Posted on Jun 18, 2009
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
Posted on Sep 13, 2009
canwoodjc
  • 3301 Answers
SOURCE: I need to know what
I believe thats made by Murray and powered by Briggs and Stratton, if this is the case I would need the model number and motor size,, you can just replay to this answer and I can locate that info for you
Posted on Jul 07, 2011
I have a vermeer 1600a wood chipper with a 300 6clinder ford engine. I am looking for a manual to help me do some repairs on it.
Holy cow! A bit out of my area. If it's the engine, go to FOMOCO website of course. If it's the machine, go online to the manufacturer, if they're still in business. I'm sure you've tied this, but just in case..... If they're not, get manuals online for chippers of similar size. The technology may be similar, too. Manuals for discontinued machinery are often on eBay, too. Good luck.
May 16, 2014 | Heavy Machinery
Iput to much oil in a briggs and stratton engine on a wood chipper the engine has seized up what can i do
Drain out the oil, take out the spark plug and see if you can get it to turn. Turn by hand or wrench not an electric starter
Aug 28, 2013 | Briggs & Stratton Briggs Stratton...
I need to know what size spark plug does my dynamark wood chipper take.
Jul 07, 2011 | Garden
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Can't start Chipper
Unplug the spark plug wire FIRST.  DO NOT SKIP THAT.  Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse.  I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards.  You have to disconnect the spark plug because the engine could fire when you turn it.  Even if it doesn't start, one good kick could hurt you pretty seriously.  So, go unplug the spark plug and do your thing.
Apr 18, 2009 | Heavy Machinery
Have an old wood chipper/shredder don't know the make but the engine mode is 130902. I can not get it started and when I could it was very hard to start. I do not have the manual so I can't tell what the...
Magneto coil adjustment is normally about 1 newspaper thickness for a guide. The spark plugs for these small engines usually are preset in about the right range, & I rarely gap then when I work on the small engines. Also check your carb to make sure its clean while you are at it. Rick
Apr 08, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
What is a chipper?
Most of our industry refers to chippers or chipper-shredders as pieces of equipment that can handle both wood and leaves. These machines have both a chipping device and a leaf-shredding mechanism. This mechanism is basically a hammer mill, cylinder or drum with a series of pivoting flail-type knives. The chipper-shredder usually is a smaller machine and may include a vacuum to clean up leaves. These machines can be self-propelled or stationary. Most chippers are disc-type, consisting of a large, heavy, rotating disc with knives mounted to it and are for chipping wood only.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Woodchipper support
Deaths have occurred involving the use of wood chippers. Never allow children around or near the area when you are using a wood chipper. No one under the age of 18 should be allowed to use a wood chipper alone.
Aug 27, 2008 | Tanaka TIA-350s Post Hole Digger -...
Wood Chipper how to
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Heavy Machinery Logo
Top Tecumseh Heavy Machinery Experts
methjd
Bilral
Level 1 Expert
szanghi
Are you a Tecumseh Heavy Machinery Expert? Answer questions, earn points and help others
