Question about Epic A17U Upright Exercise Bike
Cannot get computer to work
Have tried to adjust reed and magnet
Will not turn on. flashing blue light
If the console only reads zeros or the controls do not function properly, try adjusting the reed switch. You will need a Phillips screwdriver to remove the motor hood and adjust the reed switch. Unplug the power cord, remove the motor hood and locate the reed switch, which is on the left side of the belt pulley. Rotate the pulley until a small magnet comes into view next to the reed switch. Loosen, but do not remove, the screw on the switch and move the switch with your hand until the gap between the switch and the magnet is 1/8 inch. Tighten the screw and replace the motor hood. The Controls Are Not Working on NordicTrack Treadmill LIVESTRONG COM
Feb 09, 2015 | Nordic Track Nordictrack C2500 Treadmill...
Lights
Check this and adjust it:
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console.
clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
11_29_2011_3_44_52_pm.gif11_29_2011_3_45_23_pm.gifGood luck. sincerely
E.CUADRA
Nov 29, 2011 | Epic View 550 Treadmill
Proform 625 turns on all leds on console and hangs.
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
After you did these adjustments, please tight the flexible cable from key panel vs. Display board.
and then connector from display board vs Lower Boar or Main controller Board.
Try to clean the keypanel with contact cleaner (spray from radio schack or computer store.
Finally attached my block diagram that I did for people like you. You will see how the main controller board has 90% of the functions for treadmills.
You will have powerful resultant what is faulty!11_28_2011_4_29_03_am.gif11_28_2011_4_32_32_am.gif
Nov 28, 2011 | Exercise & Fitness
C2255 treadmill - everything works but the console light no longer comes on - nothing in manual to show what the problem could be.
See the diagram adjust for 1/8"
After that: Do the next: 1) Tight the flexible cable from keypanel vs Display board.2) Tight the connector from Display Board vs Lower Board( Main Controller Board). See the block diagram that I did how the main controller board has aprox 90% of function from the any treadmill
Nov 26, 2011 | Nordic Track C2255 Console (treadmill)
Precor C 962 Display works, but when start key press nothing happens!
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Remember :The controller for console or display have circuit for magnetic swithc.
Nov 19, 2011 | Exercise & Fitness
Light blinking, not working
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_15_2011_12_05_38_am.gif11_15_2011_12_06_02_am.gif
Nov 14, 2011 | Exercise & Fitness
I have a Life Fitness 9100, and the display is dead, it worked fine the last time it was used two weeks ago. Thanks!
Adjust and clean very softly.
Oct 22, 2011 | Life Fitness 9100 Next Generation...
Our Nordic Track C2255 has worked great... until today. I went to start it and after placing the saftey magnet to turn it on, the incline rises and keeps trying to rise even after it has reached the max %...
Watch the videos+Tip:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
12_1_2011_4_57_07_pm.gif12_1_2011_4_57_26_pm.gifObserve as the main motor controller board has 90% of functions of the any treadmills. Now you will have powerful resultant and determine what is wrong.
good luck, sincerely G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
Sep 24, 2011 | Nordic Track C2255 Console (treadmill)
`STUCK KEY` shows when machine is switched on and will not work
Try to tight the flexible cable from Keypanel vs Display board and then tigh the connector from display board vs lower board or main motor controller.
Clean the keypanel with contact cleaner spray(radio schack or computer store):
adjust according with diagram attached 1/8" aprox +see the block diagram how the main motor board has aprox 90% of functions of any treadmills. Now you will have powerful resultant what is wrong.
sincerely Good luck, and God bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Sep 23, 2011 | Precor C956i Treadmills with HR /...
Console getting erratic numbers and motor will not run. i have checked the reed. my father does not remember how tech support had told him to reset console. Was working intermittenly before we checked...
fINALLY: Test the Optical Sensor if have it
http://www.youtube.com/watch?v=E-q-uS4t6so
Aug 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
Epic A17U Upright Exercise Bike Logo
44 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
