Question about SuperMicro C7Z87-OCE Desktop Motherboard - Intel Z87 Express Chipset - Socket H3 LGA-1150 - 1 Pack ATX - 1 x Processor Support - 32 GB DDR3 SDRAM Maximum RAM - Serial ATA/600 RAID Supported Controller - 3 x PCIe x16 Slot - 4 x USB 3.0 Port - HDMI
Loud continuous beeping - SuperMicro C7Z87-OCE Desktop Motherboard - Intel Z87 Express Chipset - Socket H3 LGA-1150 - 1 Pack ATX - 1 x Processor Support - 32 GB DDR3 SDRAM Maximum RAM - Serial ATA/600 RAID Supported Controller - 3 x PCIe x16 Slot - 4 x USB 3.0 Port - HDMI
    New Friend:
  • 82 Answers
There is nothing in the motherboard manual about a long continuous beep:
Supermicro Products Motherboards 4th Gen Core C7Z87 OCE
I would check to make sure none of the cables are backwards (ie the 16 pin is the likely culprit). Otherwise, I would attempt to boot using a single stick of RAM, check the CPU socket for bent pins, or check the warranty status and return the product for repair/replacement:
http://www.supermicro.com/support/rma/
Posted on Apr 21, 2014
My Keurig Elite 40 (B40) beeps continuously when I turn it on.
Heating element may be damaged...return for exchange asap
Mar 05, 2013 | Keurig Elite B40 Coffee Maker
I HAVE A CONTINUOUS BEEPING SOUND WHEN I PUT MY HP G60-445DX LAPTOP ON
This sounds like a motherboard issue, sub out the ram memory one at a time. If there is no change suspect the motherboard, option main board replacement.
Jun 19, 2012 | HEWLETT-PACKARD G60-445DX Notebook
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Makes loud continual beeping noise after boot up and fan sounds very noisy
The beeping is most likely bad RAM, the fan running loudly may be a result of the system not being able to detect it's own temperature (which can also be caused by RAM if the system can not post correctly) or it could just be a dirty fan.
Mar 19, 2010 | Acer Extensa 4620 Notebook
System stops working. Task manager show nothing working and then a loud speaker beeep continuously
Is there a sequence to the beeps? If there is then it is telling you the problem with the beeps. For example "beep" "beep" "beep-beep" would be a processor register failure. Also check that the cpu fan is working...it might be overheating if the fan has stopped.
Nov 24, 2009 | Dell Inspiron 6400 Notebook
Dell D620, freeze with continuing lound sound Beep
Try running a good registry cleaner like Glary Utilities or Advanced Widowsystems. That should help. Also try checking for driver updates on Dell site.
May 20, 2009 | Dell Latitude D620 Notebook
Cycle Signal Volume beeps from loud to soft
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
Feb 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Computer gives 1 loud continuous beep on startup
unplug your memory and reseat it... that should fix the issue
Robert
Please take a moment to rate this solution.. thanks
Jan 26, 2009 | HP Pavilion M9040N Elite Desktop PC
Beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Nov 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
SuperMicro C7Z87-OCE Desktop Motherboard - Intel Z87 Express Chipset - Socket H3 LGA-1150 - 1 Pack ATX - 1 x Processor Support - 32 GB DDR3 SDRAM Maximum RAM - Serial ATA/600 RAID Supported Controller - 3 x PCIe x16 Slot - 4 x USB 3.0 Port - HDMI Logo
182 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
