Korg pa1x keys problem
When i press a few keys very soft they sound double and very high. please help me if u can , thank u .
2 Suggested Answers
  • 521 Answers
SOURCE: recently repaired a fault in
there must be some connections fault on this new board or may be the another board is not working too.
Posted on Aug 15, 2008
Factory reset korg pa1x ?
To factory rest on Korg pa1x you should take few steps and as a warning i have to say you will lose all your existing setting and data.
First download the operating system version 3:01 into four floppy disks. you can find it for mac and PC versions.go to http://www.korgpa.com/support/discontinued-products/korg-pa1x-pa1x-pro.html
Second: if your Pa1x has Hard drive transfer the factory resource file from the above link into hard drive.otherwise you need to copy factory resources to FDDs again.
Third: turn off the Keyabord and insert the FDD1 into floppy drive. once you turn the keyabord if you press intro instead of OK it will wipe all the OS and setting on your keyboard and then start installing fresh Operating system.
Fourth: turn off and on the keyboard. then go to this and go to utiliy and find your HDD and load the factory resource. I mentioned if you don't have hard drive then go to FDD and insert the FDDs for factory resources and load them one by one. then turn off and on the keyabord.
All done.
Regards
Arash Armand
Sep 04, 2013 | Computers & Internet
I have a Korg Pa800 and it now has 1 key sounds louder than the others, I dont know if I had pressed something wrong. Please help
hi Peter
try to change to organ sound if is not happened the problem is the rubber contact under the keyboard (clean o change the rubber)
Sep 01, 2013 | Korg Pa800 61-Key Professional Arranger...
My Korg N364 is OUT of TUne Please help
go to global mode and find factory reset. or go to the transpose in global mode. it must be +00 or 440.000. or try to find the transpose in edit mode of the bank selected
Aug 27, 2009 | Korg Legacy Collection
Need to get back a default software/application but how?
Resetting the BlackBerry device is a useful way to resolve issues and is usually the first step in troubleshooting the BlackBerry device. Knowing the differences between a hard, soft, double-soft, and master reset ensures that the correct troubleshooting method has been chosen. Note: Backup all applications before resetting the BlackBerry device using the Backup and Restore tool on the BlackBerry Desktop Manager.
Please follow the below steps or resetting
Performing a SOFT reset on the BlackBerry device Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Note: This does not apply to the BlackBerry® Pearl™ smartphone.
Performing a DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
If you liked my response Please do Rate this solution.
May 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Split two hands for two different sounds
The SP200 does not have any built in ability to split the keyboard between high and low. My guess is that you were seeing someone using this keyboard as a midi controller for a sampler (or sample player) and they had assigned various samples to keys or key ranges. This can be done using Reason fairly easily. The setup would be in the sampler you use however and not the keyboard.
Hope this helps.
bd.
Jan 03, 2009 | Korg Pa800 Synthesizer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
