Question about Eiko 49315 - FML27/65 - 27 Watt CFL Light Bulb - Compact Fluorescent - 4 Pin GX10q-4 Base - 6500K -
Need to remove 4 pin CFL
How to remove from socked
How to fix steering lock on peugeot 307??
it depends on the problem. if the pin is locked in and the key will not move it, it will need to be drilled out and a new lock to replace it. if its sticking you need to get at the lock and get the pin lock out with key and remove the locking lock pin and remove the lock and give it a good sock with some oil and clean out the in lock housing.
Mar 06, 2014 | Cars & Trucks
I've never had to change a CFL bulb like the GE 35972 in my kitchen ceiling fixture. It looks like a squared off pretzel with the socket in the middle and facing up to the ceiling. It's been in there for...
CFL bulbs are held in place by a friction fit, but it is a very tight fit. Grasp the CFL by the sqaure plastic base and pull firmly away from the socket. You may have to wiggle it a little, but don't try to pull it out by the globe because they are very fragile and break easily. I would imagine the pins would be interchangeable with some other model, depending on the number of tubes and the number of pins. Just take your bulb with you to compare. If you have any specialty electrical supply houses in your town, that would be a great place to look. I'm giving you a link where you can order them if all else fails, but CFLs have become pretty common, so you shouldn't have too much trouble finding one.
http://www.e-conolight.com/lamps/lamps-compact-fluorescent.html
May 01, 2011 | GE Vacuums
Need pin settings for cfl-s969L,. need pin out info
download it in yahoo.com or i will send you later
Dec 24, 2009 | Computers & Internet
Why do CFL light bulbs make the 2wire hpa unit not work?
I have not experienced the trouble you are suggesting. CFL do product radio interference. There may be a connection. To prove it - remove the CFL.
Everyone is interested in reducing electrical use and CFL is a good choice. For this particuylar installation, you may want to go with a more expensive alternative, LED. Search LED on Google, you will get a lot of leads and you son't believe the choices you will have
I hope this helps you. Thanks for posting your question in FixYa.com
Please vote.
thanks
a
Nov 13, 2009 | Computers & Internet
Eiko 49315 - FML27/65 - 27 Watt CFL Light Bulb - Compact Fluorescent - 4 Pin GX10q-4 Base - 6500K - Logo
77 people viewed this question
Top Eiko Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you an Eiko Fish Expert? Answer questions, earn points and help others
