Question about Thruster 20" Chaos, Freestyle, Boys Bike, Blue/Green
Need help adjusting brakes - Thruster 20" Chaos, Freestyle, Boys Bike, Blue/Green
Hi need help pls I cant slide my drum brake cover over my newly changed shoes in my 98 ford festiva
THIS IS BECAUSE THE PISTONS IN THE CALIPER HAVEN'T BEN PUSHED ALL THE WAY BACK IN,.WITH THE NEW SHOES THIS MUST BE DONE IN ORDER TO REASSEMBLE.
Feb 22, 2015 | Ford Cars & Trucks
What brake adjusting tool should I buy to adjust (rear) shoes?,it has front brake pads.
Usually you can pull the e=brake about 10 times,it should adjust them,or do it more.
Nov 30, 2014 | Cars & Trucks
Failed inspection, (at a Toyota dealer) was told rear brakes need adjusting. How do I adjust and are they not self adjusting??
To adjust the rear brakes you need to turn the adjusting screw, which is a piece between the brake shoes that has indents around it to help you when adjusting. You need to turn the adjuster enough so that with the drum, it will spin but is firm. Let me know if you need more direction.
Mar 28, 2011 | 2009 Toyota Corolla
Can i adjust e brake @ handle, or do i need to pull rotors and off to do it?
They should be self adjusting. Why are you trying to adjust them...too tight ? Too loose ?...you may just need new pads as the e-brake uses diff brakes than the hydraulic system brakes. Hope this helps !
Mar 09, 2011 | 2006 Chevrolet Trailblazer
My 2007 Honda accord hand brake lever is already high, that tells me it need to be adjust. I look under the car tried to find where to addjust it, it may be inside the rear wheel, can you help me?
Your brakes need to be adjusted first.Then worry about the handbrake.Don't get this wrong or it could be very bad.Get the brakes done,adjust the h/brake.
Cars can go but they MUST stop.Dont shortcut on the brakes.
H/brake adjustment is usually beside the h/brake lever
Hope this helps
Jan 17, 2011 | 2007 Honda Accord Sedan
Parking Brake doesn't work. I have adjusted the
Check your rear brakes and their adjustment. If parking brake is seperate check them also. The brakes have to work and be adjusted properly then adjust parking brake.
Sep 08, 2009 | 1996 Jeep Grand Cherokee
2003 silverado HD adjust emergency brake cable?
first you need to check the rear brakes ,the emergency brakes work off the rear brakes, there is an adjustment on the center of cable that goes between both rear brakes,hope this is some help,thanks robert b.
Jul 06, 2009 | 2003 Chevrolet Silverado 2500HD
My brakes are not braking correctly, I need to know where to adjust
Hello eddher:
The Following is a General Instruction File I Made for this Problem. Readjust the Brake Rods to the Original Positions. Now to Adjust the Brake Pads. Tighten the Center Adjusting Nut Until SNUG. Loosen the Adjuster Nut 1/8 Turn and Try the Brakes. If Braking is Not to your Satisfaction, then Adjust the Center Adjusting Nut on the Disc Brake Assembly Slightly (1/8" at a time) Until the Proper Braking is Achieved.
The Brake Assembly is on the Left Side of you Hydro Transaxle.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers GTH 2448 T in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View. The GTH 2448 T 917.279260 has a Hydro transaxle Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 07, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Brake drums
the brake shoes are likely stuck in the grooves worn into the drum. You need to back off the brake shoe adjusting wheel to loosen the brake shoes.
Also, the face of the drum usually has a couple of threaded holes you can screw bolts into to help pull the drums toward you.
First, hit all the way around the brake drum with a big hammer to loosen the drum from the center hub.
Then, istall the screws to help pull the drum.
to back off the adjuster with a screwdriver:
  1. NOTE: If the brake drum will not come off, follow these steps.
  2. Loosen the brake shoe adjusting screw nut (2047).
  3. Using a screwdriver, move the brake shoe adjusting lever (2A176) off the brake adjuster screw (2041).
  4. NOTE: Move the adjustment tool handle downward to loosen the brake shoe adjusting screw nut.
    Use the Brake Adjustment Tool to loosen the brake shoe adjusting screw nut.
please give a good rating if this helps.
May 03, 2009 | Mazda B3000 Cars & Trucks
Rear brakes need ajustment on Buick Lesabre
I don't know if this works on a Buick but I have had two cars that the auto adjusters worked when you used the parking brake, I rarely use the parking brake so I got in the habit of working the parking brake 20 times or so at oil change time.
Apr 15, 2009 | 1998 Buick LeSabre
Thruster 20" Chaos, Freestyle, Boys Bike, Blue/Green Logo
37 people viewed this question
Top Thruster Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Thruster Cycling Expert? Answer questions, earn points and help others
