Question about Proform Exercise & Fitness
Proform xp 680 crosstrainer treadmill trouble shooting
The incline motor was disconnected when I acquired the unit. When I connect the motor and insert the safety key the motor only runs in one direction. I can reverse the polarity of the motor power leads to reverse the direction of rotation but it still just continues to run and does not appear to be affected by the proximity sensor when I run the motor in either direction.
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
SOURCE: proform xp 680 crosstrainer treadmill keeps
Mine did the same thing. I ran it to a dedicated non GFSI circuit and the problem was eliminated
Posted on Nov 29, 2009
  • 43 Answers
SOURCE: My ProForm 530 is stuck in the incline position.
plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
Posted on Jan 07, 2010
SOURCE: Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
Posted on Jan 24, 2010
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Posted on Feb 02, 2010
Incline trouble.
You most likely have a wiring harness problem. Get parts at usedtreadmillrepairparts.com
Dec 25, 2013 | Proform 7.0 Crosstrainer Treadmill
Incline motor ran away, won't work after replacing
see the diagram attached and test test the input motor voltage, if there are the motor is faulty.see my personal TIPS.
God bless you
Nov 18, 2012 | Proform XP 580 Crosstrainer Treadmill...
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
My pro-form tredmill is stuck on incline and will not let me do anything. I am freaking out. Please what do I do?
TAKE FRONT COVER OFF, THERE ARE 3 WIRES 1RED 1BLACK 1WHITE. REVERSE THE RED AND BLACK, THE INCLINE WILL DROP WHEN IT GETS WHERE YOU WANT IT DISCONNECT WHITE WIRE. YOU NEE TO REPLACE MOTOR OR USE IT IN THAT POSITION LEAVE WHITE WIRE DISCONNECTED.
Mar 20, 2010 | Proform 675 Crosstrainer Treadmill
Incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 19, 2010 | Proform CrossTrainer Treadmill
Proform 740CS runs okay but the incline does not
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
My treadmill proform835QT fails to incline. What can I do?
Try to calibrate the incline: Hold down the stop and speed up buttons at the same time then insert the key. release the buttons the press the stop button and release then press the incline up button. the incline motor should go all the way up then all the way down with - - on the console. If the unit only moves just a and inch or so or the motor just hums , the incline sensor is faulty.
Jan 15, 2010 | Proform CrossTrainer Treadmill
Trouble shooting
Your belt may need adjustment. to tighten you need to use the allen key (supplied with the unit)
Sep 30, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
16 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
