Question about Bernina Sewing Machines
Using the Aurora 440 QE with the embroidery module, it does not recognize that the module is attached. I have also tried it on my sisters 440. The cord from the module is plugged in and the dongle cord is also plugged in. Should I assume the embroidery module cord is not making the connection or the dongle cord? The only item that shows up on the computer screen is a picture of a computer with the dongle coming out of it. Any suggestions?
  • Bernina Master
  • 9,289 Answers
Hm, sounds like the machine is not recognizing the dongle or the embroidery cord. You may need to have Bernina test it for you.
Posted on Jun 12, 2017
Ajkill
  • 2035 Answers
SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
Posted on Jun 27, 2008
SOURCE: Driver for the Bernina Aurora 440 QE
Buy a new installation CD!!!
Posted on Nov 13, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180E Embroidery module not recognized
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Posted on Feb 11, 2009
SOURCE: what is a dongle? My version 3 keeps saying attach dongle but I don't know waht that is.
A dongle is a usb plug in used for mobile broadband connections and should be available from your mobile phone shop!
Hope this helps
from Evelybird
Posted on Feb 18, 2009
  • 371 Answers
SOURCE: No Dongle Attached Error Msg
You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
How do I get my BSR to work on my 440QE? I plugged it in, but I don't see a light on the foot. Can't make BSR 2 work? BSR2 is on my screen, but won't run.
Try BSR 1. I have a 440 and only one of the BSR settings works--don't know why--just is.
Manual:
BERNINA aurora 440 QE Support BERNINA
Check to make sure the BSR is firmly plugged into the machine head. Don't know why they made this so difficult. I find I usually have to practically stand on my head to find it and then plug it in.
If it still does not work, perhaps Bernina did not calibrate the BSR to your machine. They recommend, whenever it goes for service, to be sure to bring the buttonhole foot and BSR so they can be calibrated.
Apr 04, 2017 | Sewing Machines
Where is the bobbin switch for bernina 440
What do you mean by "bobbin switch?" I have a 440 but cannot think of what you could possibly be asking.
Nov 04, 2016 | Bernina Sewing Machines
Bernina 440 QE thread sensor shows thread is broken when it is not
Try enterng this in the google search block; "bernina 440 qe maintenance" it comes up with a lot of informaton and even videos.
Nov 27, 2014 | Bernina Sewing Machines
Why wont my Bernina 170 QE embroidery unit work
Electronics fail eventually. It is a bummer because I bet you love your old Bernie. Electronics are nothing for the novice to mess with unless they have loads of component level experience. I would take this to your sewing tech and have them check it out. (maybe get a new one?)
Jul 21, 2014 | Bernina Artista 170
Using my Bernina 440 qe in the embroidery mode needle is hitting the foot.Worked fine yesterday, today I have broke 3 needles.
could you possible have attached a foot that is not the correct one for your Bernina one that is a smaller mm
Mar 03, 2014 | Bernina Sewing Machines
Hope I helped.
Jan 25, 2009 | Bernina Artista 180
Sewing Machines Logo
35 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
