Question about Jenn-Air Dishwashers
Door hinge problem
When opens, just drops open.
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
tzweeb
  • 318 Answers
SOURCE: washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Posted on Dec 28, 2008
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Posted on Jun 15, 2009
  • 24 Answers
SOURCE: DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Posted on Jul 25, 2009
  • 189 Answers
SOURCE: LG Model LD-14AW2 - loud bang and door dropped
Hello- Parts are available locally at app. parts store. Need complete model #. Usually have to pull out unit to install. Replace both sides. There will be a spring, sometimes with a cord to pull door up. Either part can break, so get both. Not easy, but you can save a bit by doin it yourself. Hope this helps. -Thanks- ED
Posted on Feb 28, 2010
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
Washer door drops when i open it.when i close it i have to lift door. hinge seems loose
This may seem obvious, but tighten all the screws on the front panel, especially around the door hinge area. A #2 Phillips screwdriver is all you need. Also, try to see where it's dropping - is it at the door itself, or does the entire hinge assembly sag where it enters the washer?
Jun 21, 2014 | GE WCVH6260FWW
Passenger door has dropped and has to be lifted to close can any one give any guidance
Your hinges are bad. Depending on the model, sometimes th hinge pin(s) can be replaced without removing the door or hinges. Usually replacing the upper hinge will cure that problem.
Aug 29, 2017 | 2006 Peugeot 207 1.4
Mitsubishi shogun drivers door jams when open
Check you hinges and make sure one is not broken. Sounds like it is. Compare your drivers door to the passenger door to see if you notice any difference in the number of hinges, as the center one may have gone into the door so you won't know it's missing uless you compare.
Mar 21, 2014 | Mitsubishi 3000GT Cars & Trucks
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
I dropped a casserole dish on the inside glass of my oven door and has popped the glass out. I was wondering if could take the door of so i can see if can stick the glass back.
To remove the door: Open it fully. Look for a hole on each hinge in which to put a nail crossways to hold the hinge open when removing the door.
Without holding the hinges this way it is near impossible to reinstall the door against the force of the hinges.
Dec 29, 2009 | Ovens
I can't open the door, I have used the key and tried the combination. I hear the lock disengage but the door won't open. It appears to be stuck. How do I get it open?
You may have the same problem as me.
The bolts in the opening side may have sheared off of the ratchet arm that pulls them into the door. It's a casting using inferior quality metal.
I was lucky. The problem was found when the door was open.
The only way to open the door will be to turn the safe (with everything unlocked) so that the hinged side is along the floor and try tapping the top so the bolts drop into the door (the bolts are joined together).
If the safe has been secured and cant be moved get a grinder and chop the hinges off. With the hinge side bolts withdrawn the door can be opened. Sentry doesn't do this spare, so a new safe is required.
Dec 10, 2009 | Sentry Fireproof Safe
Can you change the way the door opens on the neptune washer
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Dishwashers Logo
15 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
