Question about Toshiba 20AF44 20" TV
Toshiba 21S3E TV Problem
Hi
This is a Toshiba model 21S3E
when turn ON power come and go for few scand and stay for while then off
could you till me this is due power capacitor fuiler or fram CCt. ?    Thanks
2 Suggested Answers
eitan
  • 291 Answers
SOURCE: TV Toshiba 27af53 shuts down after a few minutes.
please give more detail
Posted on Jun 03, 2009
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Hi when the tv has been tured off for a while it wont turn on again till its unplugged and then it still sometimes takes a few attempts to turn it on its a toshiba tegra 42 1080p
Main power supply regulator board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Tv turns off
Hi, your power board is in a weak state. this is being caused by major component failuer. replacing the power board will fix this issue.
Jul 09, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Toshiba MW20FM1 DVD section quits
am toshiba authorized servicer-have same model in shop for same problem-dvd board is defective-new board is about 290 from toshiba america parts-tv is actually made by orion with toshiba name stuck on outside-orion is junk-cost more than new set to fix-junk it and buy a panasonic-so far they still make their oun stuff
Mar 11, 2008 | Toshiba MW20FM1 20 in. Combo
TOSHIBA 21S3E
Your set needs demagnatizing if it hasn't been dropped. Only a tv repairman has a demgnatizing coil. However one try: unplug it and turn it back on because all standard tv's have an automatic demagnatizing coil circuit around the tube inside. but doesn't always demagnatize completely.
Jan 02, 2008 | Televison & Video
Toshiba 20AF44 20" TV Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
