Question about HP Compaq Presario R4000 Notebook
Presario r4000 keeps rebooting
I don't have a recovery disc and I don't wanna lose my family pics on hard drive. I'm broke too. :(
mailtoravi
  • 186 Answers
SOURCE: recover problem
This can happen if the Recovery Partition is corrupted or the Hard Drive is bad.
 First, I recommend you to check the Hard Drive using the Hard Drive test utility available in the BIOS by following the steps below :
Start or restart the notebook and start tapping the F10 key.
This will get you the BIOS Setup window.
In this. go to the Diagnostics or Tools tab where you can find the Hard Drive test utility.
Select using the Up/Down arrow keys and press enter to start the test.
Make sure that you complete the Full test which may take around 80 minutes to complete.
If the Test result is Pass, we can come to a conclusion that the issue is with the Recovery Partition which is corrupted.
You need to purchase the Recovery Disks for your Notebook in this situaiton.
Contact HP Chat Support to get the exact link to order the Recovery Disks for your Notebook.
However, if the Test Result is Fail, you need to take backup of the data in the Notebook and replace the Hard Drive with a new one.
Hope this helps...
Posted on Nov 19, 2008
Muggs01
  • 71 Answers
SOURCE: I have a compaq presario r4000 it turn on but the windows don't
You can call compaq & order a recovery cd or you could just reload an operating system.
Posted on Jan 15, 2009
  • 909 Answers
SOURCE: Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
Posted on Aug 27, 2009
nyilasrobert
  • 627 Answers
SOURCE: SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Posted on Oct 22, 2009
  • 161 Answers
SOURCE: recovery disc problems
the cd recovery you have need connect to hard disk by some files system when u change new hard miss these files so cannot do it. only u recover by use ghost from image
Posted on Jan 19, 2010
So my compaq presario R400 needed to be rebooted beacuse it was not working properly, the mute button worked but not the volume keys, It somehow lost the D drive and I couldn't put any cd's or...
what OS.?
XP?
R4000 , did you forget a zero?
with AMD (Athlon 64) 12 years old?
sounds virus infected to me or worse
reload the install disc, windows recover disc , yet?
1: hdd bad.
2: infected
3: overheating (dustbunnies or fan dead)
4: or fiddled with by kids (hopeless)
Mar 24, 2017 | HP Compaq Presario R4000 Notebook
I'm trying to copy the ntldr files from my xp disk but everytime I type in the copy command I get "access is denied". Is there something I can do without losing everything cause I had a lot of...
hi
follow these instruction exactly . this will work
If you get the "NTLDR is Missing" error, follow these instructions:
1. Load Windows XP CD into CD drive.
2. Make sure BIOS is set to boot to CD drive.
press F8 or F11 to get into BIOS
3. Boot the computer from CD.
4. At menu, press "R" to load Recovery Console.
5. Select the installation to be fixed.
*The following instructions assume CD-ROM is labeled as drive D and the hard drive partition the windows installation is on is labeled as drive C. Replace the letters accordingly.
6. Type "COPY D:\i386\ntldr C:\" and press ENTER.
7. Type "COPY D:\i386\ntdetect.com C:\" and press ENTER.
8. Remove CD and type "EXIT" and press ENTER (to reboot your computer).
God's speed
Nov 15, 2010 | HP Compaq Presario SR1303wm PC Desktop
How do i reboot my cpu to factory settings, programs ect..?
You can either use your recovery discs that came with the computer and re-boot the computer with the disc in the drive. The computer should ask you to"press any key to boot from cd" when re-booted. If it does not you will need to go into the BIOS and change the first boot device to the cd-rom drive. Or if your computer did not come with any recovery discs you can use the recovery program if it is built into the hard disc drive. You can usually activate this by pressing "alt" then "f10" when the computer first starts up. Sometimes the computer will tell you what to press to enter recovery mode when it first boots up.
Nov 14, 2009 | Compaq Presario C700T Notebook
Cant access laptop apart from boot menu f5 f12...keeps saying tring to fix windows but not getting anywhere...i have alot of photos on there i do not want to lose...have toshiba recovery disc but that will...
Hi There, try booting in safe mode to download your photos to a flash drive or cd. When you first turn on laptop, and see the curser upper left side of screen, keep pushing "f8" to enter safe mode boot. Select "safe mode with networking" and continue on to save pics. Good Luck...
Oct 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
I have about 39gb of family pics and music saved on my freecom 250gb external hard drive and I have had to reboot my system with a backup file using ACER e-recovery management. since then my external hard...
In the control panel, go to administrative tools, open computer management. On the left side, there will be a "Disk Management" section, use that to assign a drive letter to your hard drive.
Sep 30, 2009 | Acer Aspireā„¢ T180 PC Desktop
Jan 15, 2009 | HP Compaq Presario R4000 Notebook
Compaq R4000 failed to open the window - how to fix the problem?
I had the same problem with mine. There is an option of "repairing" on the recovery disc that actually keeps all files and software intact. It worked for me, much better than the full re-format of the hard drive and new install of the OS.
Aug 23, 2008 | HP Compaq Presario R4000 Notebook
Dvd drive
You might try unistalling the drivers and reinstalling them from the device manager. However, this sounds like a harware issue, your DVD drive may be shot.
Jun 20, 2008 | HP Compaq Presario R4000 Notebook
Compaq Presario R4000 boot error
Hello Joresnore,
When booting to the XP install disk you should arrive at a "Repair Install" option that will not format the HD (I am reasonably sure it has to be SP2 though). It will just overwrite Windows system files, .dll's , etc... I think this is only available when using an XP SP2 disk so if your installation disk doesn't contain SP2, I would look for one that does and give it a try. I have had multiple successes using the repair install method without loss of data.
Good luck.
Feb 28, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
