Question about Whirlpool Accuwave Microwave Oven
Replacement vent Can you point me to a replacement vent 8205195 or 8203195?
Replace the vent fan
Russ
Try heating a cup of water for two minutes. I bet it doesn't. A sign of a magnetron being defective is a loud hum and no heating. Unit is then not economical to repair.
Dec 09, 2014 | Microwave Ovens
Need replacement oven air vent
try a company called e spares on the internet they do most parts or can find them
Jan 28, 2014 | Panasonic NN-H275 Microwave Oven
Bought a new white ice whirlpool microwave and the auto vent won't turn on automatically no matter how hot or how long we cook food....we can turn it on manually. The authorized service man replaced...
This should be a warranty replacement if you can get Whirlpool to respond. Try returning the microwave to the point of purchase for replacement
Aug 04, 2013 | Microwave Ovens
Unable to find replacement grill vent cover
are u talking about the mica looking thing inside if so let me know
Apr 01, 2013 | Microwave Ovens
My Micro vents into the kitchen instead of venting up the exhaust vent. What could be wrong
The fans on an over the stove microwave can be rotated up to 180 degrees depending on how the installer intends to vent the hood. Your fan is pointed forward and venting into the kitchen through a charcoal filter. If you want to vent through the ducting and out of the kitchen, you'll have to drop the microwave down off of the mounting bracket and rotate the fans in the back, pointing the dicsharge upward for a vertical vent, or 180 degrees, if it discharges out the back (wall vent). In both cases, an adapter is necessary, and can be obtained at any hardware store.
Best regards, --W/D--
Aug 08, 2009 | Tappan TMT104E1 Microwave Oven
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
I have a GE JVM1650 with an apparent magnetron issue. It was manufactured it 2005 so it's probably not under warranty at this point. I think I will just go out and buy another microwave. Wondering what...
GE Customer Service is
here and they can tell you what model would be a "drop-in"replacement.
Feb 01, 2009 | Microwave Ovens
Replacement model for jvm152h
Please clarify which model Spacemaker Micro you have .. and Spacemaker microwave ovens can be configured to vent inside or out simply by repositioning the blower assembly prior to mounting it to the wall bracket so turn it on and determine where the vent air is being distributed ( outside or inside) ..
Oct 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
