Question about DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker
Delonghi coffe maker not heating
Coffee side not heating
  • 5 Answers
SOURCE: Delonghi Coffee Maker
You need to take the unit to an authorized repair shop and have the heating element replaced
Posted on Feb 09, 2008
  • 512 Answers
SOURCE: DeLonghi DC89TTC Series Coffee Maker does not work
Your unit is probably wet on inside by bottom heater. Take apart and dry inside of unit. A hair dryer works good for blowing all excess water out and helps dry. If unit is still in warranty go to http://www.delonghi.com Call number they will tell you if unit is still in warranty if so they will replace for shipping costs.
Posted on Jun 17, 2009
  • 5 Answers
SOURCE: DeLonghi BCO120T coffee maker side does not work.
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
  • 668 Answers
SOURCE: My coffee maker, a DeLonghi
Most likely, it has an open thermal fuse or failed circuit control board. If it is under warranty replace
it, else you need to take to near by service centre to get it repaired.
Hope this helps.
Shane
Posted on Mar 06, 2011
mc1bean
  • 3053 Answers
SOURCE: water leaking from bottom of
Hello, cat
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
I need parts for my delonghi caffe espresso
Hi Towanna-
Nice coffee maker! I have bought parts for similar coffee makers at this link (provided). Their site usually has a detailed diagram of the parts associated with each make/model of maker and a list of availability and their cost. Good luck!
DeLonghi BCO110 Parts List and Diagram eReplacementParts com
Apr 01, 2014 | DeLonghi Caffe Figaro BCO110 Espresso &...
Heating up please wait nothing happens then general warning comes on what can i do
Standard problem with some Delonghi coffe makers.
The problem is with heating device inside.
There is thermal fuse - that have production leak i think
Need to remove cover and repair this fuse
Apr 01, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Instructions for a cafe nabucco
Go to http://www.delonghi-accessories.com then go to customer care and ask them for instructions, they are very helpful.
Jun 05, 2009 | DeLonghi Caffe Nabucco BCO70...
Jun 03, 2009 | DeLonghi DC89TTC Coffee Maker
I need replacement parts - lid
Go to http://www.delonghi-accessories.com you can order replacement parts. If your model is older go to customer service and they will tell you if you can still buy part.
May 16, 2009 | DeLonghi DCU72 Coffee Maker
Delonghi coffe pot DC312T --can't find a replacement carafe. Sams Club doesn't have them anymore.
I threw out the coffee pot. The replacement carafe was more expensive than the entire coffeepot!
Apr 17, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
