Question about Toshiba Computers & Internet
Brand new battery showing full but when you pull the power cable out machine sattelite pro c50-a 1e0
Laptop showing battery full but pulling out power cable machines closes machine brand new model satellite pro c50 -a -1e0
SOURCE: I need the manual to Euro=Pro, Model 7500, Craft N' Sew Please..
http://homeappliance.manualsonline.com/ex/thread/view/idThread/159782
This one is in 3 languages, but it is worth the read. The diagram to choose the patterns from the frony of the machine are on page 28. Hope this helps.
Posted on Sep 23, 2008
  • 461 Answers
SOURCE: Toshiba Satellite P105-T2050 - DVD player does not work
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 21, 2008
  • 112 Answers
SOURCE: I need audio drivers for my laptop
Have you tried the Toshiba web page? under support and drivers?
Posted on Mar 07, 2009
SOURCE: ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
Posted on Jul 16, 2009
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
Hi i have a problem with my toshiba sattelite pro 6100. When i pressing power button there is only green led signalising dc power, and orange from battery charging nothing else. Nothing seems to runing...
Hi Domnik,
First, you want to make sure that the battery has a charge. Leave it plugged in for 30 minutes and then try powering on the laptop. If this does not work you may have an issue with the power cable or battery.
Try a new power cable and batter if you have them.
If not, you may want to contact Toshiba Technical support for assistance if the product is still under warranty.
Regards,
G33k
May 04, 2011 | Computers & Internet
1980 caddy coupe deville has brand new battery, brand new alternator but the battery keeps draining.
Something is staying on after the key is turned off. easy way to find out what is staying energized is pull all fuses, disconect the battery, then put the amp meter in line with the positive side of the system between the positive battery post and the positive cable end. then put the fuses back in one at a time a see which one draws one or two amps. that will lead you to the draw down circuit. If nothing is pulling the battery down then the battery is not getting a full charge. Check the ground conection at the motor side of the cable and also the ground strap between the motor and the firewall
Apr 18, 2011 | 1980 Cadillac Deville
I have this laptop and I had to buy a new ac power adapter as my other one died Now my laptop says the battery is full but when I pull out the power cable it does What can I do to fix this
You did not specify what happens when you pull out the power cable? The laptop turns off? IF yes then the battery is past its maximum recharge cycles. You will need to get a new battery to resolve this problem.
Jan 27, 2011 | ASUS F5VL-A2 Notebook
Tryin to locate the cmos battery in a Toshiba L300 laptop
Turn off the laptop and pull the laptop batteries first, use a screwdriver to open the cover screw
After open the cover, and then slowly pull the cable red-black coil , which is the CMOS battery cable connecting the laptop to the board.
But make sure that you know what your doing because you can cause problem to then battery,motherboard or worse!!
Feb 05, 2010 | Toshiba Satellite Pro L300 Notebook
The battery wont charge
return your computer. there is a serious problem with either the charging system or the battery.
Aug 16, 2009 | Toshiba Satellite Pro P300 Notebook
New battery charges but won't work
YOU HAVE A FUALT CONNECTION TO THE BATTARY AND NOTEBOOK POWER SUPPLY AND MAY BE A WIRE COME LOOSE INSIDE THE LABTOP
ROD
Feb 04, 2009 | Toshiba Satellite A105 Notebook
[[ACER WONT TURN ON]]
You might of fried the whole motherboard when it sparked. Check if there is a fuse. Bridge the gap, and it should turn on. If not PULL THE PLUG.its something else that went wrong.If you don't, it smells really bad. Ive learn't from experience...
Jul 28, 2008 | Acer TravelMate 2300 Notebook
Battery problem
u try new power plug unit supply next i would try that or does battery show full charged but wont start then mobo has bad power chips on it they can redo them or u can buy new mobo to install in also cheak screen cond cables ect
Feb 04, 2008 | Toshiba Satellite P105-S6024 Notebook
Computers & Internet Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
