WHRILPOOL WASHER LSQ9010KTO WILL NOT FILL WITH WATER
2 Suggested Answers
Greg20
  • 149 Answers
SOURCE: washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Posted on Jun 12, 2009
WFW9050XW00 WHRILPOOL FRONT LOAD WASHER WILL NOT FILL WITH COLD WATER
First thing I would do is to take the Filler Hoses off (Make sure you turn the water off before disconnecting). There is a Screen in hose connector and it traps water. If the Hose Filter is not clogged, then you have an issue with the Selector Switch, Valve inside the machine, one of the Solenoid's or the Control Board has went bad. Start with the Easiest First, then work your way into the more difficult aspects...
Jul 20, 2014 | Whirlpool Washing Machines
My washer comes on and fills with water and i can pump out water but its not spinning or doing any tub movement at all, i have the whrilpool calyspo top load
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Replace the lid switch with this part.
Jan 02, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
"LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
there is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't spin makes banging sound
Jun 11, 2009 | Whirlpool Washing Machines
The washer fills up with water and then does nothing after that.
Hi The problem is more then likely the lid switch.Can you take the front panel off to check.One the front at each corner,2 clips use a puddy to slide in & release the front
I About some years ago Whrilpool started putting the lid switch in motor circuit and if the switch is bad it will only fill but will not spin also you may have a sock stuck in the water pump if you Can You hear a hum low in Machine?
Mar 14, 2009 | Whirlpool Washing Machines
Whrilpool washing machine will not fill
May I first suggest that you turn both the hot and cold water off to your washer and check the screens installed in the back of the machine. A lot of times dirt and debris can clog the supply lines. After you check the supply lines, turn the water on with the hoses in a bucket. This will make sure that you are getting water to the machine. Replace the lines, and turn the supplies back on. If you are still not getting any water, you are looking at a bad water solenoid.
Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
