Hhow to open the tape casette compartment
I lost the manual and don't know how to open the cassette tape compartment. RCA Rp3538 Micro Cassette Recorder
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Posted on Dec 31, 2007
welcomejee
  • 10594 Answers
SOURCE: problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Posted on Oct 22, 2008
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
Hi, I have a RS2620 and the Casette belt is broken... where can I find the casette belt? Help
All you have to do is measure the diameter of the belt (in mm) and the put that and Cassette belt into Google. If you live in the UK Maplin have a range of them.
Jun 05, 2010 | RCA RS2620 Single Cassette Deck
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Bmw casette
Hello.
You need to take out the cassette deck from the car. open the cassette deck by removing the various screws, once open, there is a small plastic gear which you need to wind manually which will slowly release the cassette.
Oct 26, 2008 | 1999 BMW 323 Series
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Oct 22, 2008 | Audio Players & Recorders
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
66 people viewed this question
 Grubhead
Grubhead
