Question about Refrigerators
Kenmore smart reach refrigerator
Refrigerator is warm inside temperature setting is on 7 and the refrigerator is not getting cold
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
SOURCE: Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Posted on Mar 18, 2009
SOURCE: Refrigerator not cold. The motor is blowing but
unplug the refrigerator. get to the compressor remove the cover on the compressor, remove the brown or white relay. the compressor also has an overload, but that maybe on the top or connected to the relay. remove the wires, remember where they go, shake the relay, if it rattles it's bad. you will need to get a solid state relay to replace the bad one..Good luck
Posted on Aug 29, 2009
  • 93 Answers
SOURCE: What temperature should we set the refrigerator and the freezer?
Totally up to you. Most people set them for the temp they like their milk and the firmness of their icecream
Posted on Sep 13, 2009
heatman101
  • 43501 Answers
SOURCE: FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
Why is the top of refrigerator warm and bottom freezer cold
Sounds like you may have either a bad defrost heater or a bad defrost thermostat or both
Aug 18, 2015 | Kenmore Refrigerators
I have a whirlpool refrigerator model wsf26d4exb00. the refrigerator side is cold only on the bottom but the top selves are warm
Make sure you condensor fan is running. Our gets clogged up with dog hair sometimes and when the fan cannot run the fridge cannot cool.
Aug 19, 2014 | Whirlpool Refrigerators
Refrigerator condensation inside
Whether on the outside of the cabinet or the inside it is because you have warm moist air hitting the coldness of the refrigeration. It can also happen if you put hot food into the cabinet.
Also at the back of the inside of the cabinet there is often a small drain that empties the water from the defrost cycles. Check that they are clear.
Feb 02, 2018 | Frigidaire Refrigerators
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
Kenmore 106.9631680 keeps running all the time,all the gaskets are tight and the coils are clean
Hello there:
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jul 14, 2010 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
