Question about Home
Remove shower restrictor from aquasource shower head
  • 37 Answers
SOURCE: flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Posted on Nov 12, 2008
  • 19 Answers
SOURCE: American Standard Cadet 2-handle tub & shower
All you should need to do is remove the shower head and make sure that their isnt any dirt obstructing the opening ,also if their is a restrictor like you said you need to remove it.This should make a big difference.
Posted on Feb 09, 2009
  • 185 Answers
SOURCE: Just installed a Moen 3867 hand held shower. There
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Posted on Mar 04, 2010
  • 119 Answers
SOURCE: shower head has little preasure or water volume.
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Posted on Mar 28, 2010
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
How do you remove water saving device for Glacier Bay tub and shower set 108191 in shower head?
You should be able to unscrew the shower head to expose the restrictor and remove it.
May 30, 2016 | Home
I have bought several shower heads as the spray pressure is low but none have helped. The pressure is ok on low setting on half heat but too cold. On full heat its too hot on min setting. Help plz ?
The problem is that all shower heads sold now have to be low water volume. You can take the restrictor out and see if that helps. Look for a blue or white plug type insert in the fixture that has a slot on it. Pull it out and you should be good.
http://homeguides.sfgate.com/remove-water-restrictors-showerheads-27817.html
and http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html
Jun 22, 2015 | Home
The shower is coming up with low pressure soon as you turn on checked filters all ok
Remove the shower head and check the water flow. If it is good, look inside the head for a restrictor that is designed to reduce the flow rte. It can be either rubber or plastic, with a smaller hole than the inside diameter of the pipe. Remove the restrictor and re-install, making sure that you still have a rubber washer to prevent leakage.
Best regards, --W/D--
May 16, 2011 | Home
I have a Moen single handle tub/shower faucet. I cannot yet get much pressure to the shower head, there is good pressure from the faucet. I have placed the shower head in vinegar with no improvement. ...
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Feb 14, 2011 | Moen & One Handle Tub & Shower Faucet
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
How do you fix hot water shuts off during shower with Model N-069M-OD installed December 2006?
Try flowing more hot water with your shower. During the summer you end up mixing alot of cold water and very little hot water (because your cold ground water isn't so cold in the summer). When you get close the minimum flow rate of the appliance, it will start to short cycle (fire on and off). Here's some recommended things you can do:
1) Clean the shower head - remove scale deposits and or clogging
2) Widden flow restrictor - most shower heads have a flow restrictor on the back of the showerhead; It consists of a rubber washer with a hole in the center. You can widen the hole using a drill bit.
3) remove the flow restrictor - this should be a last resort
Jul 22, 2010 | Noritz 6.3 Gallon Residential Tankless...
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
Feb 07, 2009 | Delta & Victorian 5 Spray Showerhead
Flow restrictor
Nov 12, 2008 | Delta & Victorian 5 Spray Showerhead
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
