Philips 20PT633R 20" TV Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Philips 20PT633 has started shutting off mid program.
My Philips 20PT633 has been shutting off by itself for several months now. Sometimes, the screen will go blank, but the power light stays on. After a couple of seconds, the screen will come back. It will then shut off again, but this time the power light goes out.
Now, sometimes it shuts off and the power light stays on, the screen never does come back and it will not let me manually shut it off, I have to unplug it.
Darial Jr Lasaria
Level 3:
  • Master 379 Answers
  • Posted on Jun 08, 2009
Darial Jr Lasaria
Master
Level 3:
Answers
379
Questions
0
Helped
120783
Points
1040
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Sometimes when I drive several miles and then stop. When I try to start it again, the engine turns over but won't start It is like it floods itself.
Have you tried to hold the gas pedal to the floor ? Ford's have clear flood mode strategy programmed into the PCM , if you hold pedal to the floor the engine computer disables the fuel injectors . If it is flooded holding to the floor will clear it out .
Lcd tv shuts off by itself and then turns on by itself
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
3answers
Dryer stopping mid cycle
You have to test several parts, common causes are defective termic sensor, or fault program control.
Post model number for more details
Three colors are not together
Convergence problem needs two ic 's to fix.
Display problem
A fuzzy display is not likely to by caused by programs on your computer. Is this an LCD flat panel monitor or a regular CRT monitor?? If it's a CRT, the problem could be with the high-voltage power supply, which would need to be diagnosed by an experienced computer1.gif or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
2answers
Flashing red light and shutting itself off
try to elevate the projection tv about an inch...
it well most likely work...
it's a ventilation problem.
Wont' Hold settings for channels, tuners, sound, ect.
just wondering if you ever got the problem fixed? I have the same problem. [email protected]
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
