Question about Sony MDR-RF960RK Consumer Headset
Replacing the battery on a h760 head set - Sony MDR-RF960RK Consumer Headset
Tip
Battery replacement in Xantrex XPower Powerpack 600 > 600 watts 12 VDC >...
Battery replacement will require opening the case of the Powerpack 600. The four rubber feet must be removed first (Phillips head #2 screwdriver). Next the two orange handle halves come off starting on the radio side. The screw heads may be either 9/32" or 1/4" heads depending on age of your Powerpack 600. Use either a 9/32" or 1/4" nutdriver to remove the screws. The orange handle halves swing open like a clamshell at the carrying handle and lift off. The orange handle half on the flashlight side has two hidden latches in the handle area that must be released with a flat head screwdriver first before that half can be fully removed. Now that the orange handles are out of the way, slip off the bumpy rubber handgrip from the gray handle. On the radio side of the gray plastic case are 9 Phillips head #2 screws that are in recessed holes to remove. Once those screws are removed, the gray plastic case seperates in half and you can unplug the two pin connector going to the radio and set the radio half aside. You are now inside the Powerpack 600 and can replace the battery if needed.<br><br>Replacement 12 volt, 28ah battery numbers:<br>Sealake # FM12280<br>Zipp Battery # 12V-28AH-T3<br>CSB # GP12260<br>Powersonic PDC-12260<br>Tempest # TD28-12<br>Panasonic LC-C1228PG<br>Universal Power Group # UB12260<br>BB Battery # BP28-12
on Sep 01, 2013 | Xantrex XPower Powerpack 600 > 600 Watts...
Cannot make Logitech H760 headset work with telephone on iPhone
This headset is not compatible with smartphones because it uses a USB wireless adapter to communicate from a computer to the headset.
Aug 30, 2013 | Logitech H760 Wireless Headset
I use a H760 wireless headset of Logicool. Today, the wireless receiver usb showed only blinking green light. For 5 minutes later, the green light was disappeared. The headset didn't work. Can I...
Yes, it normally works for me to put the usb into a different usb slot. This will reinstall the driver for a different usb slot and make it work perfectly!! Make sure it is charged, and that you have powered it off and back on first.
May 18, 2011 | Logitech Computers & Internet
Dymo letra tag print is unreadable
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
May 17, 2011 | Office Equipment & Supplies
When I connect the USB for headset into system it messes up my internet wireless connection. when I take USB out my internet will work fine again
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
Mar 02, 2011 | Logitech H760 Wireless Headset
When I connect my USB into system it messes with my wireless internet connection. As soon as I unhook it my internet connection is fine again.. Any Suggestions?
I think the problem is, that your wireless router is too close to the wireless connector of the headset, it's just a guess, but try to move them at least 3 meters apart.
The other thing that could cause trouble is the driver from logitech. Maybe your firewall is disabling all internet connection when the driver is trying to connect to the internet. Try to disable the firewall/antivir.
Or it's just the same frequency, but that's probably not possible.
I hope I could help you =)
Battery replacement
mcdevito75 here, Not so easy to replace the batteries as 1 Norelco system has batteries soldered to a circuit board, and you wold also need a set of torx screwdrivers available at any auto parts store to remove the old batteries, lift the sahver head to view thes escrews pr check online at Norelco.com Battery replacement, you may have to replace the shaver.
Jun 19, 2010 | Norelco Quadra Action 7864XL Electric...
How do I get my Gear Head Wireless Keyboard shut down.
It has no off function. It uses little to no power when in stand-by (Not in use). It even has an auto off function after a delay. Just replace the batteries when they run out.
Apr 12, 2010 | Gear Head Wireless Bluetooth V 2.0 Desktop...
Sony MDR-RF960RK Consumer Headset Logo
18 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
basssplayer
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
