Question about GE 24-7/8" Convertible Portable Dishwasher - White-on-White
Water leak portable dishwasher
Ge portable dishwasher gsc3408k00ww. Water leaks underneath when machine starts to intake water!! :(
SOURCE: GE NAUTILUS DISHWASHER
The motor seal is leaking, had the same problem with mine.
Posted on Dec 01, 2008
  • 8 Answers
SOURCE: gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Posted on May 01, 2009
  • 58 Answers
SOURCE: My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Posted on Jul 01, 2009
thunderalley
  • 432 Answers
SOURCE: water leaking underneath our GE GSD2030Z01 WW dishwasher
lose hose clamp or bad motor seal, or bad seal
Posted on Sep 13, 2009
heatman101
  • 43501 Answers
SOURCE: Leaking from underneath.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
,fhjsuj
Posted on Sep 29, 2010
GE (Triton) dishwasher is leaking at point where intake tube connects with the frame of the dishwasher ("intake manifold"?)
There is not an intake manifold per se, only a water valve that is electrically controlled. Could be loose connection or worn out.
Jul 20, 2015 | GE Dishwashers
Ge dishwasher about 7 years old as soon as we start it we hear the water turn on to fill but it does not fill water it imeadily start draining
Hello
Water Not Flowing Properly
Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
Sep 12, 2011 | Dishwashers
Leaking water underneath dishwasher
most dishwasher has a kick plate at bottom ,,remove kick plate ..be careful turn unit on let water fill system..and just look ..just look and see where the water is coming from...warning,,most parts of a dishwasher are not grounded,,,please be careful
Oct 10, 2009 | GE Dishwashers
Dishwasher leaks from bottom left corner
If its just that corner check that it is level (if not leak could be somewhere else)
Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
Most likely a loose hose connector or hole in the rubber hose
This hould help you
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
sounds like the water outlet has a leak - probably a simple 'o'ring problem - these can wear.
Aug 17, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Gld5860l00ss QuietPower2 water leak
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
GE 24-7/8" Convertible Portable Dishwasher - White-on-White Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
