Question about Maytag MAV7600 Top Load Washer
Remove agitator have older model wwa7600 with phillips screw on top of agitator is this the only one holding agitator down
2 Suggested Answers
  • 2287 Answers
SOURCE: REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Posted on Nov 03, 2009
Testimonial: "Super fast and accurate info. Thanks so very much."
My Whirlpool model sm8525079 will not spin. It will make a humming noise that I assume is the agitator but no real clue. It will drain though.
this is not a modle #,try raising the lid if a top loader and look low center under lid. if top load you may have a broken drive coupling.pretty easy fix once you get cabinet off.2 phillips up front on older on back on some,all at the very out side edge of control panel,some newer have end caps to remove for front screws.newer have spring clips.use putty knife between washer top and panel out side edge.two spring clips remove pump,two screws and clips remove motor,coupling is next.
Dec 10, 2013 | Washing Machines
Pants tie stuck around agitator on older model top loader. How do I remove the agitator?
If it is newer you yank the agitator off there by grabbing the neck
Feb 08, 2011 | GE Washing Machines
I have an older Kenmore top loading washer model 11082994100. The machine is in excellent condition and I replaced the main control board a couple of years back. Issue is lately when machine goes to end of...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082994100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Nov 14, 2010 | Washing Machines
The agitator seems to be stripped out - I need info on how to disassemble the agitator
Te newest ones are the easiest, a square hole can be unscrewed after removing the splash guard and belch dispenser.top Older models have a nut to remove. You must use an extension and socket for that. I have a nice video i found online: HERE
After I get the agitator out I set it on the floor and hold it down with my feet, I grab the top and yank it apart. I remove the old worn out agitation dogs and replace them with part number 80040 around $5 here. Line it all up and snap it back together without breaking the plastic locking tabs on the base of the agitator. While putting back the agitator take care not to make it come apart. This sounds hard but it is not. Anyone can do it.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't get top part off the agitator
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
I want to replace the aggitator but cant pull it
Some models have a fabric softener dispenser located at the top of the agitator that must be pulled off so you can get access to the fastener that holds the aggitator onto the transmission/motor shaft. Some are just pressed onto the motor shaft and after years of use, get gunked up (yep, that's the technical term for it!). You can pour some hot water down the agitator tube to help flush out the gunk and that should make it easier to remove the agitator.
Also, check along the bottom of the agitator to see if there is a small hole that might be concealing a locking set screw that is holding the agitator onto the shaft. It varies from model to model, so look all over and around the agitator before exerting any force in an attempt to pry it off the shaft.
Try to get your hands under the bottom lip of the agitator at the 3 and 9 o'clock positions and try to rock it back and forth while pulling up and it should work itself free.
Just be sure you have removed any screw or hex headed fastener that could be holding the agitator onto the shaft 1st!
Jul 28, 2009 | Kenmore Washing Machines
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Kenmore washer model number 110.22642100 won't spin
check the lid switch. if the machine is agitating and washing but won't spin it is probably the lid switch. this is the switch on the top front right of the machine with the lid open. you will see two phillip head screws holding it in place. easy fix is to unplug machine and take screws out of swith, clip wires and use wire nuts to connect another switch.
Apr 07, 2009 | Kenmore 22642 Top Load Washer
Washer is making a grinding noise. It want spin or agitate.
sounds like ur shaft is stripped motors about 100 bucks ur call prob better get a new one
Dec 31, 2008 | Kenmore 22422 Top Load Washer
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Maytag MAV7600 Top Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
