Question about Sub-Zero 601R
601R no lights come on no compressor - Sub-Zero 601R
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Doe anything come on? A fan perhaps? If you look closely at the display you can see the numbers even with the lights out. I think I would check that you actually have power to the unit first.
Posted on Feb 07, 2016
If all the lights are out, check the bulbs. They sometimes get build up on them and need to be wiggled to make better contact. a 1/8 turn will sometimes do the trick. If there is no light, the panel will not illuminate. It is back lit with the 4 bulbs under the plastic top panel. No light, no panel light. Compressor has a 4 minute delay. It is possible that a switches are bad at the bottom of door. Do a check with a multi-meter, one switch is always on, the other is always off, if you push it and the status changes, the switch is good.
Posted on Feb 02, 2016
Light sub zero 601
Check the light switch by wiggling it side to side, if the light comes on replace the switch, if not check the bulbs also. It rare to have issues with both. Has this been serviced recently? Check the bulbs to assure they are snug in the sockets also.
Good Luck
Jul 31, 2014 | Sub-Zero 601R
Sub-zero refrigerator on but not cooling
thats right, if compressor running you most likely have to go thru this repair.
Jul 21, 2014 | Sub-Zero 601R
Your thermostat, or compressor (motor) is defect. Or the cooling fluid has leaked away. (used to be freon)
To be sure let a technician have a look.
How do I reset my Sub Zero 601R refridge so the vacuum seal comes on?
wow never heard of a vacuum sealing door on a fridge. all I ever knew of are magnetic ones and I find no mention of this feature searching .
Jun 23, 2014 | Sub-Zero 601R
Sub zero 601R not cooling properly
The display does not show air temp, and it is not "live". It uses both thermistors to calculate the internal product temperature of the stuff in your fridge. You would have to have it open for a very long time to affect the reading. Also, the reason the compressor will not run after leaving the door open, is because the computer will not allow the compressor to turn on until the evaporator reaches at least a 38 degree reading, no matter what the set temp is. This is designed to ensure that the evaporator is not "iced up" when the unit turns on, thus causing a frost up. They call this an "off cycle defrost" that is how they defrost the coils without using a heater. When you disconnect the thermistor, it doesn't know what the evap temp is, so it runs in a default mode.
Jan 16, 2014 | Sub-Zero 601R
I have a sub zero 601r that has stumped me. We had a power surge and the board went. I got a new one and installed it. The new one has error codes of 07 & 08, the service light flashes and the ICE...
Hi!
I believe the codes in this particular case mean that there is an open or mixed up connection on the board, or that the board you got is not for the unit you own. You may try unplugging the unit for a few minutes to reboot the board and see if the codes disappear. Here is a description of the codes:
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp's
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp's
This is the Control Board for your unit (601f, 601r) Call 800-269-2609 to verify with serial number off model tag.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 05, 2011 | Sub-Zero 601R
Got subzero 601R & 601F. don't have lower kickplates. what r those part #'s?
TRY THIS PART num. 0166110 for both. is the same part. DEPENDS IN YOUR SERIAL NUM. MAKE SURE TO HAVE THE COMPLETE MOD. NUM AND SERIAL NUM. WHEN ORDER YOUR PARTS..... good luck. LEAVE YOUR COMENT IF IT WAS GOOD FOR YOU.... THANKS
Oct 30, 2009 | Sub-Zero 601R
Subzero door left open and now motor won't start
yeap. wait to cold back. the fridge have a sensor to shut the lights off. the reason; LIGHTS REALLY POWERFULL. CAN BURN THE LIGHT COVER
Jul 15, 2009 | Sub-Zero 601R
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Sub-Zero 601R Electrical
have you checked the main power button on top of the unit, behind the grill?
Jan 02, 2009 | Sub-Zero 601R
Refrigerators Logo
74 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
