Question about Pool & Spa
Laars pennant ignitors lockout
Trouble shooting ignitors lockout new ignitors new ignition controls and the gas is good 7.wc
5 Suggested Answers
SOURCE: Won't lite, checked water flow and gas both good
could be the pressure switch.
Posted on May 24, 2009
  • 83 Answers
SOURCE: I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Posted on Jul 08, 2009
  • 11 Answers
SOURCE: I have a Laars Lite2 gas spa heater. I just
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
Posted on Jun 28, 2010
adamh294
  • 310 Answers
SOURCE: automatic gas shutdown light comes on. replaced
This sounds like your fan prover (air switch)
check switch continuity, and air switch tubing.
Replace if neccessary.
Sometimes these vinyl air tubes just melt
Posted on Nov 01, 2010
Laars ignitors lockout
need more info does the ignitor light?
Feb 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Check ignition control message
souns like bad fenwal or make sure ignitor is lighting
Jun 06, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Trying to heat pool . turns on the it will go off and say check ignition control
make sure gas pressure is good see if ignitor is glowing if not replace ignitor
Dec 19, 2010 | Jandy LAARS IGNITION CONTROL ASSEMBLY,...
Automatic gas shutdown light comes on. replaced ignitor that was not glowing. worked friday. today troubleshooted new ignitor is fine. replaced ignition control box. still no power (voltage) going to...
Nov 01, 2010 | Jandy Laars Lt 250,000 Btu Heater
My heater is showing a ignition lockout fault, how can I fix this
turn off that resets it check gas to see if on outside unit and inside at gas valve then try again if doesn't light see if ignitor is lighting if not replace if so see if safety circuit is ok
Sep 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Laars Lite2 gas spa heater. I just replaced the Fenwal Electronic Eignition. When I turn the power on it starts the start-up process, the gas starts to flow, but no clicking of the igniter, just...
Jun 20, 2010 | Jandy Laars Lt 250,000 Btu Heater
Hi , I am not getting any flame at all to my Laars lite 2 125,000. Waterflow is good and gas is fine. Have had plumber out but he had no idea> How can i check what component is faulty. Regards. Martin
It is hard to say this could be anything. If you don't have a book for this you can go on line and get an owners manuel and it will have a trouble shooting flow chart you can follow and see where the trouble lyes. Print your manuel out as their so many wonderous things in it. Good luck
Nov 09, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Dec 09, 2008 | Heating & Cooling
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
