Question about Dell Dimension 5100 (D51L1) PC Desktop
Hard drive keeps losing space lol
My hard drive <250> gig is losing available space. one day it reads 178 gigs left the next
  • it's reading 165 gigs left on the os side.
  • Ad
    • 47 Answers
    Are you surfing the internet a lot?  You may be getting a lot of temporary files.  Here is something to try.  In internet explorer go to tools / internet options / delete cookies, delete files (all offline contect) and clear history.  This should help some.  You are always going to go down in space.  Windows updates automatically on a regular basis.  This will cause a decrease in available hard drive space.
    Posted on Oct 27, 2007
    SOURCE:
    I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
    Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
    Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
    Jun 16, 2017 | Seagate Computers & Internet
    Dropped xbox 360 with built in 250 gig built in
    You Damaged the DVD drive and the laser came out of alignment so therefore it wont read disks anymore D:
    Jan 01, 2012 | Video Game Consoles & Games
    I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
    i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
    Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
    Unable to access space on Lacie remote drive
    The easiest way will be to format the disk drive. Highlight the icon, right click and format.
    Feb 07, 2010 | LaCie (300770) 250 GB Hard Drive
    I decided to upgrade the hard drive to a Western Digital 250 Gig from the original 30 Gig. I also added the RAM module-- making it 512 now. The problem is that after loading the original restore CD's that...
    is it formatted as NTFS FAT32 file system can only reconize 127 you must enable largr drive in the setup. but if you are using a image it wont give you that choice you will need to get a windows xp disk and use the driver / program disk to install you original software. you can also partition the drive into two particians to separate and it will then reconize the drives then you can mount the othe drive to a folder and then reclain all the drive space.
    Jul 21, 2009 | Toshiba Satellite 1905-S277 Notebook
    Free up hard drive space
    It's probably just misreporting the capability. The camera uses 2 folders that are approximately 16 gigs (magically all hard drives lose a few gigs don't ask me why). But in FAT32 partitions, only 4 gigs can be used at the most at one time, so it might be guessing there are just 2 4 gig capacity folders.
    Jan 27, 2009 | JVC Everio GZ-MG57 HDD Camcorder
    External hard drive disk space
    Hi
    Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
    T.Boopathy
    Aug 17, 2008 | Western Digital My Book Essential Edition...
    Data lose in 8 gigs memory stick
    you cane help yourself in this case.
    you should change it using warranty option or try to go to dealer for serrvice
    faulty hardware prob
    Jun 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Backup hard drive to an external hard drive
    "what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
    That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
    Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
    Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
    Hard drive space
    Well I'm gonna need more information i.e. What operating system are using with the device etc. And also check disk management(i assume u are using either windows 2000 or XP) to see how much total disk space is available on the device. Disk Management(Right Click on My Computer then click Manage. On the left pane expand Storage then got to(click on) disk management. When there u'll see all the disk connected to your system at the time on the right pane. Look for your disk then scroll down and you'll see how much is available and how much is used!
    Apr 18, 2007 | LaCie (300952U) 300 GB Hard Drive
    Dell Dimension 5100 (D51L1) PC Desktop Logo
    66 people viewed this question
    Clive
    Clive
    Alun Cox
