Question about Onkyo HT-R590 Receiver
Ht-r590 receiver has no sound
System working fine last night, turned on today and have no sound in any mode, i.e. tv, dvd, fm
4 Suggested Answers
  • 1121 Answers
SOURCE: onkyo receiver memory power backup not working
there is a special memory chip who keps thre config. The older models has a battery who power memory offline, and that battery has 5 years life, and needs to be replaced. or new models has a eeprom who keeps data above 10years, normaly some chips has small defects who reveal after 4 or 8 years, normaly also needs to be replaced.
Posted on Dec 22, 2009
SOURCE: I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it. http://www.highdefforum.com/high-definition-receivers-recorders-players-tivos/121956-repairing-onkyo-htr667-aka-606-a.html
and the youtube vid: http://www.youtube.com/watch?v=gj0x5S9ez5U
Good Luck!
Posted on Jan 13, 2011
  • 27 Answers
SOURCE: My ht-r690 receiver's video out stopped working. sound works, tv and cables work (tested on another system) but no video shows up on tv through the receiver. any ideas?
Well there are two possible reasons. 1st- make sure that to do a factory reset on the amp. while it is on Press DVR/VCRat the same time press the power button (Standby) clear will show on the screen.system is now back to defaults try the video.
2nd If the video still not working check the TV out settings. Press Setup - Input Out put assign - Monitor Out- Make sure it's set to HDMI. and the resolutions is set to Through. if this setting is ok and you problem is not solved. it could be an issue with the board or your hdmi device it self.
Let me know?marc
Posted on Nov 10, 2011
Everything OK, except no sound from the FM tuner.
You may have many different issues in the FM circuitry. Do any other FM stations come in?
If you are interested in having your Marantz repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 21, 2015 | Marantz SR6006 Home theater receiver...
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Samsung remote for HT-D5550 not working with BD - only TV - HT-D5550
Wipe the front, where the receiver eye shoot be with a soft clothed cloth.
Otherwise there is no new equipment connected like a kodi player or so? It demand sometime a slot and block other equipment.
Feb 04, 2018 | Samsung Ht-d5500 Blu-ray Receiver
I have a Samsung 5.1Ch Home Cinema System. HT-Z320 and a SONY Integrated Digital TV DV3. Is there any way that i can set the surround up so that the tv can be played througt surround system and not just...
I just hooked up my HT-Z320 today. I had to use an optical audio cable to connect the audio output from my TV to the optical audio input in the samsung receiver (it's the only optical jack on the receiver). Then with your samsung remote in DVD/Receiver mode, click the Auxiliary button (near the top right of the remote). Hope this helps.
Nov 18, 2009 | Sony Televison & Video
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
TV/DBS No Picture
please apply a spray over your selection switches and press it many times.-check for mute not on.repeat speaker setup and confirm all speaker are on-
May 14, 2008 | Denon AVR-1706 Receiver
No sound today after wrong button on remote ??
I had this happen with mine also and finally determined the A/B speaker. That is my only experience.
Jan 03, 2008 | Onkyo HT-SR800 System
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Onkyo HT-R590 Receiver Logo
165 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
