Question about Asko T712 Electric Dryer
Asko t712 won't tumble - Asko T712 Electric Dryer
2 Suggested Answers
SOURCE: I need to repalce the
I took the top and back of my unit apart. Then from the back it is still not the eaisiet of tasks.
Posted on Mar 10, 2011
My asko t721 dryer is one week old and i do not have a manual.it stopped in the middle of a cycle. it had 3 bath towels in it.. it starts when i push the button but will not stay on for more than a few...
Hello, welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a excessive long vent or flex vent being used ( stay away from flex venting ) plugged lint filter, plugged vent ot partially plugged etc.
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate further...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko T712 Electric Dryer
Element in the back seems to be heating but not spinning around. Cleaned filter.
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Asko T712 Electric Dryer
I need to repalce the belt on an Asko T712 front loading dryer. Do I go in from the front or the back?
Oct 13, 2010 | Asko T712 Electric Dryer
Where is the heater located
Are you familiar with the location of the heater hi-limit for the Asko dryer ? If so, that is the location of the heater assembly, under that housing at the back panel of the unit.
**Turn off the power or unplug the unit from the wall before performing any service**.
If not, make access to the rear of the unit possible, slide it out or whatever the case may be in your situation. You`ll see the back panel has screws all around the perimeter, but also an alongated round cover with screws around it`s perimeter as well. The heater is enclosed in this housing as is the hi-limit reset-able thermostat ( covered by a round black button like rubber cover ).
**If your dryer isn`t heating, check the hi-limit first by pushing in the middle of it`s black rubber cover before dis-assembling your dryer too far.**
Hope this answer`s your question and help`s move you forward. If so please rate this info accordingly.
Thank`s for visiting "fixya" today for your repair inquiries and good luck.
macmarkus :)
Apr 07, 2010 | Asko T712 Electric Dryer
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
My dryer wont stay hot
Check for a faulty high limit thermostat. It is a small round black device mounted on a metal plate. It is usually mounted to the internal ductwork with two screws. It can be tested for continuity using a multimeter or ohm meter. It should have no continuity. If it has continuity, it is stuck open and is faulty. I am attaching a pic showing a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
Aug 17, 2009 | Asko T712 Electric Dryer
Alarm F1 stoping dryer type T712, what the reason?
For information, behind front panel are optional hidden sensors and one of them had to be reset.
K,W.
Apr 14, 2009 | Asko T712 Electric Dryer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko T712 Electric Dryer Logo
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
