Question about LG An-tp200 Magic Touch Pen For Pentouch Tv
Lg touch pen - LG An-tp200 Magic Touch Pen For Pentouch Tv
I need a manual for my tracfone 840g
Check this:
http://www.tracfone.com/Common/English/Digital_Assets/19526.pdf
Mar 03, 2014 | HCO Stylus Touch Screen Pen Silver...
My phone is asking for a PUK code for my LG Encore touch screen.
The default PUK code is 0000.
If that doesn't work, follow the instructions located here to recieve your PUK code.
http://www.wireless.att.com/answer-center/solutionDisplay.jsp?solutionId=KB617
Mar 25, 2011 | BargainCell GTMax Touch Screen Stylus Pen...
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
My touch screen on my enV touch won't work but
better go to settings and do pen calibration. or check for the ribbon attachment properly
Sep 10, 2009 | LG enV VX9900 Cellular Phone
My touch screen is frozen, side buttons & call buttons work but the touch screen just does'nt work.
it shows the sensor on touch is not ineractive with the pen, may be you should unscrew the phone to see if flex is damaged and replace it with another one.
Jul 09, 2009 | LG Vu CU920 Cellular Phone
I have an lg touch screen phone and do not know the puk code
You'll need to call your carriers help number and ask for it. You should know the number of the phone, and have paper and a pen can usually be be than one code. Enter the codes you were given, and your phones security code will be reset.
Jun 11, 2009 | LG KU990 Viewty
Touch screen not working
take the battery off for 15 seconds and try to put it back again. goodluck
Dec 22, 2007 | T-Mobile Wing™ Smartphone
LG An-tp200 Magic Touch Pen For Pentouch Tv Logo
16 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
