Question about Dell 924 All-in-One InkJet Printer
Orange exclamation point on Dell 924 printer
Exclamation point keeps blinking. what is the issue?
  • 1003 Answers
SOURCE: Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Posted on Jan 07, 2008
  • 16 Answers
SOURCE: Dell 962 all in one printer
the yellow blinkin exclaimation point is usually an indication that there is a printer cartridge problem. It usually means the ink is low.
Posted on Mar 19, 2008
damanpreet_c
  • 69 Answers
SOURCE: dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
  • 514 Answers
SOURCE: Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Posted on Feb 28, 2009
ohms
  • 1879 Answers
SOURCE: Mac Compatible problem with Dell 924 Printer
no mac driver for that printer
Posted on Apr 14, 2009
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
The sun light and the deum icon +error message ! sign are both blinking on my Dell 1710 i have changed the toner drum but it keeps blinking should i have to change the inside drum too. because the last...
Here is a link to your printers manual. It has troubleshooting in it and explains what the error means when you see the picture of the sun with the ink drop & exclamation point blinking. It also has instructions on how to fix the error and stop the blinking.
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Oct 14, 2011 | Dell 1710n Laser Printer
My dell 1710 cant print it keeps showing or blinking " !" sign
There is a link to your printers manual that includes troubleshooting error codes. The blinking exclamation point means that the printers cover is not closed all the way. If there are any other pictures on the printers display that are also blinking like an ink drop or a sun then it can mean something else.
Oct 14, 2011 | Dell 1710 Laser Printer
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
The printer cant print it keeps showing "!" or
The blinking exclamation point means that the cover to the printer is not closed all the way. Try opening and closing the cover to get rid of this error. If there is another picture like an ink drop or a sun that is also blinking at the same time then the error can mean something different.
Here is a link to your manual for your printer that includes troubleshooting erorr codes:
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
I have an HP J4540 printer and it stopped working and the exclamation point keeps flashing. We do not know what to do - misplaced our manual. What is the problem?
Don't worry, Please press the Exclamation point, which is telling you some error has occurred while printing or scanning, once you will press the exclamation button that would stop blinking and try to print again, please let me know it works or not
Sep 28, 2010 | HP Office Equipment & Supplies
Blinking Orange Exclamation Point on 04 4runner
Since your question is listed as a 1999 Saturn SL and a Toyota 4Runner, I will answer both:
1999 Saturn SL
Typically the orange exclamation point dash warning light is indicating a problem with your brakes, parking or hand brake. Check to ensure that your emergency brake is completely disengaged.
Check to ensure proper brake fluid level.
Otherwise this could be indicating a problem with the ABS system.
04 Toyota 4Runner
Low tire air pressure. Inflate to approximately 32 PSI should correct your problem.
I hope this helps.
May 12, 2010 | 1999 Saturn SL
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
