Question about Car Audio & Video
How to wire stock ford f150 fomoco amp and subwoofer to aftermarket radio?
2 Suggested Answers
  • 8 Answers
SOURCE: hooking up amp and subwoofer to stock radio
Are you sure that you want to attempt this?
It's a nightmare if you never have worked on any kind of car stereo. I've installed my share of after market stereos, so I know it's lots of brain work and patience.
The color of the speaker wires are the only wires that you can probably identify right off the bat. It's not too complicated to attempt yourself. If you have put in an after market stereo before. Your Lexus has factory installed rear deck speakers. Look at the bottom side of the rear deck. Pop your head in the trunk and look up.
On the right speaker there are 2 wires and on the left speakers there are 2 wires.
I think that all 1991 Lexus LS models came with factory installed rear deck speakers. The speaker wires are factory installed. You want to keep these original factory wires as is, but want some thicker higher wattage amp wires for your sub woofers, but write down the 2 left and 2 right speaker wire colors with the stripes, for example the red with yellow stripe, blue with red stripe, brown with orange stripe, black with white stripe and so on. There are four wires in all. Keep your wire colors on a piece of paper, because we come back to that later on.
You will need to run the thick red power cable to the car battery. That gets bolted directly down to the battery. You'll have to remove the bottom door jam that holds the carpet down. There might be a couple screws that you'll have to remove to pull up the jam. Tuck the red wire and lead wire in under the carpet and screw the jam back on when done. Do the same for the 4 thick higher amp speaker wires and route them to the back in the trunk.
Make sure to bolt the Black Ground Cable on the Chassis of the car for a good solid ground. The one thing that will cause a short is a loose ground wire or weak ground to the body.
Remove the radio from the dash. Be careful not to break the plastic around the radio. You should probably ask somebody for help, if you can not handle it yourself.
Now we need that piece of paper with the 2 left and 2 right wire colors with stripe laid out, you can do your splicing of wires. Simply splice the left and right speaker wires with the amp normal speaker wires that lead into the amp.
The amp may have stereo RCA jacks for input, I'm not sure which you have.
Make sure to match Left to Left and Right to Right. Now the AMP lead wire gets connected to the stereos power wire. This wire may be red or yellow, but I do not think it's gray. To test the wire splice into the yellow wire with the lead and start the car and turn it off. If the amp stays on with the car turned off, then change it to another wire. The goal is that it won't drain the battery with the car turned off.
There's some troubleshooting involve with factory installed stereos and making modifications. If you get this far you did a great job. You'll have it when the lead wire is connected and the car turns off and the amp turned off and when the car turns on and the amp turns on. Make sure you do not mess with the antenna wire. that turns on and then shuts off after the antenna is up.
Posted on Aug 31, 2009
How do I hook up my subwoofer and amp to my ford f150?
to hook up the amp. drill a hole in the firewall, run an 8 or greater gauge cable (greater, depending on the wattage of the subwoofer amplifier) from the battery positive lead, thru the firewall, to the amp power +, and be sure to place an in line fuse within the engine compartment, within a foot of the battery. hook the speaker up, and then run the amplifier negative lead to a bare metal part of the cars chasss, and, finally, hook the amplifier remote power lead to the acc circuit of the interior fusebox (i usually just take the acc fuse out, stick the wire in the acc fuse receptacle, then re-insert the fuse to complete the circuit).
to run the radio signal to the amp, you can use a speaker to line level converter (if stock stereo). just splice them into the stock stereo speaker leads
Apr 15, 2016 | Car Audio & Video
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
May 10, 2014 | 1998 Ford Expedition
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
I need to know what color wire on the cd player is needed to connect to an amp to get it to start working
If you have an aftermarket radio, the wire will be yellow and usually is marked as a remote with 0.5amps of power. If you have a stock radio, I recommend purchasing a harness that allows you to add an amp. The harness should also give you RCA outputs. Hope this helps
Aug 20, 2011 | Car Audio & Video
Car audio wiring color codes.for 1988 ford f150 truck
Thanks for using FixYa.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jan 25, 2011 | Car Audio & Video
I have a 93 chevy and i want a subwoofer put in it.. is there a way to hook it to the stock radio and if their is where
you can buy a radio wiring harness at a discount store or an aut parts store, it comes with directions. Hope this helps Tim
Aug 25, 2010 | 1993 Chevrolet K1500
Installing new stereo in 2001 Ford F150
the remote wire is for remote operation of an amplifier the new radio has one because they assume that you will install subwoofers, amps etc, that wire is a reference voltage wire for a relay inside the amp
Apr 04, 2009 | 2001 Ford F150 Styleside SuperCrew
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
