Question about Singer Quantum XL-5000 Computerized Sewing Machine
Singer xl5000 the speed is stuck on slow
The lever to change the speed on my machine won't move and the speed is stuck on slow. Can this be overrided or did something possibly break on the inside of my machine?
SOURCE: I have a Singer XL5000
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Posted on Jan 31, 2009
  • 5370 Answers
SOURCE: I have a singer embroidery xl5000 machine. It will
Try removing the bobbin and cleaning the area of any stray threads or lint. When you replace the bobbin pull on the thread. The thread should pull easily and smoothly.If the bobbin is dirty inside the thread will get stuck and bobbin will get **** and thread will break.-------Check out. Thanks.Helpmech.
Posted on Dec 29, 2010
  • 5603 Answers
SOURCE: singer 427 cannot move needle
The machine timing has gotten out of adjustment. Slipping of an adjustment is causing the needle and shuttle to interfere. If the shuttle around the bobbin is not rotating, something has come loose. If you open and manually rotate the works you should be able to see what is not moving that should be. It may have lost a pin from a shaft or a setscrew. Test this without the needle in place.
Youtube has some good videos for the repair of the problem. Search for "sewing machine timing"
Here is one: http://www.youtube.com/watch?v=2OjjqmFAFLo
Posted on Jan 04, 2011
  • 4 Answers
SOURCE: My Singer Prelude machine
Hi Jos, I'm no pro but I fix lots of things. It sounds like there is a mechanical blockage that is preventing the motor from turning. If you haven't already, open all the panels or covers that reveal the mechanical workings, and remove any bobbins (and maybe the needle, if the tip is touching another part of the machine) using your hand to gently rock the motor forward and backward (unplug the cord first) look for the parts to move however slightly they may be moving. if they move with your rocking motion and stop hard, there is something that has moved out of place. Closely watch the needle tip first to see how it moves and that it and its clamp are not bumping into anything. following up the shaft, gradually and methodically look at the next parts that you can see moving, and continue checking every consecutive piece in the mech, till you've come to the back end of the motor. if you havent found the culprit by now, at least you have narrowed down the possibilities and you know your toy much better that most people. When you take it to the service man, be sure to tell him how you examined it and every thing you have learned. By giving the repairer this head start, you not only reduce their time to fix it but...they will know that you are fully aware of your machine and understand something of the problem and about troubleshooting your sewing machine. You will probably fix it yourself but if not, you wont be overcharged by anyone.
Good luck, I hope this helps.
If you want, you can E me at
derbyboab AT gmail.com
Posted on Nov 17, 2011
SOURCE: Needle and take-up lever don't move when I push the pedal
It's possible there's a part loose or broken only a sewing machine repair shop can tell what's wrong
Posted on Feb 02, 2012
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
I have a singer 3102, the feed dogs are moving up and down but they are not moving back and forth. I have just gotten this machine from a yard sale and the thread flies off of the holder when going high...
The feed dogs could very well be seized because the machine has not been cleaned and oiled recently and the old oil has dried causing the feed dogs to stick. As for the thread flying, suggestion would be to slow down. Some machines are better designed to handle the speed. Depends where the thread is flying off--if it's the thread spool, you can elongate the spool pin by sticking a plastic drinking straw over it. I have a machine that the thread frequently "jumps" out of the take-up lever--which has a slot for the thread instead of a hole. I devised a method of closing the top of the slot so the thread can no longer jump out.
For the other machine, you can search for sewing machine timing and attempt to repair it yourself. If not, then it probably needs a service call.
Apr 26, 2017 | Sewing Machines
Brother XL5000 sewing machine won't do a 4 step button hole?
you didn't say if it's a mechanical or electronic sewing machine?
do you have a manual?
if you don't here is a link for one
http://www.manualslib.com/download/22168/Brother-Xl5000.html
does the machine have a buttonhole lever that you have to pull
down before you start the buttonhole?
Nov 15, 2012 | Brother Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
Feb 02, 2012 | Singer Sewing Machines
I have a Singer XL5000--I keep getting an error message to turn off the machine--how to I solve this??
Call Singer at 1-800-4singer and ask if it an electrical problem, it sounds serious, it is free to call and why take a chance?
Sep 10, 2010 | Singer Sewing Machines
Singer Quantum XL-5000 Computerized Sewing Machine Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
