Question about Car Audio & Video
How to wire stock fomoco amp and subwoofer to aftermarket radio?
2 Suggested Answers
  • 8 Answers
SOURCE: hooking up amp and subwoofer to stock radio
Are you sure that you want to attempt this?
It's a nightmare if you never have worked on any kind of car stereo. I've installed my share of after market stereos, so I know it's lots of brain work and patience.
The color of the speaker wires are the only wires that you can probably identify right off the bat. It's not too complicated to attempt yourself. If you have put in an after market stereo before. Your Lexus has factory installed rear deck speakers. Look at the bottom side of the rear deck. Pop your head in the trunk and look up.
On the right speaker there are 2 wires and on the left speakers there are 2 wires.
I think that all 1991 Lexus LS models came with factory installed rear deck speakers. The speaker wires are factory installed. You want to keep these original factory wires as is, but want some thicker higher wattage amp wires for your sub woofers, but write down the 2 left and 2 right speaker wire colors with the stripes, for example the red with yellow stripe, blue with red stripe, brown with orange stripe, black with white stripe and so on. There are four wires in all. Keep your wire colors on a piece of paper, because we come back to that later on.
You will need to run the thick red power cable to the car battery. That gets bolted directly down to the battery. You'll have to remove the bottom door jam that holds the carpet down. There might be a couple screws that you'll have to remove to pull up the jam. Tuck the red wire and lead wire in under the carpet and screw the jam back on when done. Do the same for the 4 thick higher amp speaker wires and route them to the back in the trunk.
Make sure to bolt the Black Ground Cable on the Chassis of the car for a good solid ground. The one thing that will cause a short is a loose ground wire or weak ground to the body.
Remove the radio from the dash. Be careful not to break the plastic around the radio. You should probably ask somebody for help, if you can not handle it yourself.
Now we need that piece of paper with the 2 left and 2 right wire colors with stripe laid out, you can do your splicing of wires. Simply splice the left and right speaker wires with the amp normal speaker wires that lead into the amp.
The amp may have stereo RCA jacks for input, I'm not sure which you have.
Make sure to match Left to Left and Right to Right. Now the AMP lead wire gets connected to the stereos power wire. This wire may be red or yellow, but I do not think it's gray. To test the wire splice into the yellow wire with the lead and start the car and turn it off. If the amp stays on with the car turned off, then change it to another wire. The goal is that it won't drain the battery with the car turned off.
There's some troubleshooting involve with factory installed stereos and making modifications. If you get this far you did a great job. You'll have it when the lead wire is connected and the car turns off and the amp turned off and when the car turns on and the amp turns on. Make sure you do not mess with the antenna wire. that turns on and then shuts off after the antenna is up.
Posted on Aug 31, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
May 10, 2014 | 1998 Ford Expedition
Bmw 530i 2005(removed radio+aftermarket sub/amp/speakers/equlaizer)engine noise
You are getting feedback noise from the alternator, normally this is not an issue because you used the stock power wires for your new install. I am thinking you routed new wires to an unprotected power source on the car. One possible solution is to install an RF filter on the power line going to your components.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Oct 21, 2013 | Car Audio & Video
I need please the electrical functions of each cloured wire form the back of the unit
If you are installing a radio, I recommend you get a wiring harness. All aftermarket radios use a standardized color scheme for the wires. If you purchase a wiring harness, you attache the radio to the harness, then plug the harness into the stock vehicle harness. You can find one a www.crutchfield.com
Aug 24, 2011 | Car Audio & Video
I need to know what color wire on the cd player is needed to connect to an amp to get it to start working
If you have an aftermarket radio, the wire will be yellow and usually is marked as a remote with 0.5amps of power. If you have a stock radio, I recommend purchasing a harness that allows you to add an amp. The harness should also give you RCA outputs. Hope this helps
Aug 20, 2011 | Car Audio & Video
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
I need the stock, bose radio, color coded wiring diagram for a 1990 audi quattro v8. I'm trying to put an aftermarket radio in it.
red is 12V plus permanent
if available yellow is 12V switched
illumination is orange or orange-white
black is ground
remote for automatic antenna is blue or blue-white
but be carefull this car has originally built in amplifier so the cables for the speakers might not suite to ur new unit. check it - if u dont use the amp get new wires to speakers in ;)
Feb 08, 2011 | Car Audio & Video
I have a 93 chevy and i want a subwoofer put in it.. is there a way to hook it to the stock radio and if their is where
you can buy a radio wiring harness at a discount store or an aut parts store, it comes with directions. Hope this helps Tim
Aug 25, 2010 | 1993 Chevrolet K1500
96 monte carlo. I unhooked the stock radio and now neither my stock radio or my aftermarket radio will work in the car
Sounds like you may have touched a positive wire against the body of the car and blown a fuse
Check your fuses in the car and normally there is a fuse behind the radio in a plastic casing
Nov 20, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
