Question about HP Compaq Motherboard
Compaq Evo 410c down after AC/AC plug-in
My Compaq Evo 410c blew something when it was plugged into an AC/AC transformer and didn't turn on thereafter. There was something falling about inside. I managed to open the laptop and remove the item which I originally thought to be the (or a) fuse; however, because it's a tiny coil covered/enclosed completely in glass (ca. 4-5mm X 1.5-2mm in diameter) with no contact leads what so ever, so it can't be the (or a) fuse. I have sinced googled laptop fuses and found they look entirely different. I have also searched all the laptop's circuit boards for the holder of the glass capsule and can't find where it goes. Anyone know anything -anything at all? -Thanks.
  • donelson Jun 09, 2009
    Great idea Raksoft, but A.: there is no local store, B. there is no serial number on the capsule and as I mentioned, I cannot locate from where on the circut board the glass capsule/coil came from and C.: there are no burn marks or residue which would indicate a blown fuse. Thanks anyway. It just sux because the laptop is in otherwise in prety good condition. I'd hate to throw it out.
  • HP Master
  • 4,985 Answers
Let me read all 3 posts, why not just have one and comment to one?
symptoms for all, do nor read posts from folks telling you to find fuse clips seen in 1980s, PC, forget that. this is all SMD parts.
wiki that....
  • previous owner used a AC/power pack and blew up this LT..
  • its 19vdc not 24vac, or you WILL BLOW IT UP.
  • fixing that if true is non trivial to say the least.
  • it will not power on with battery removed, and with correct 19vdc pack attached,
  • or it does turn on sometimes but locks up in XP screens.
  • This is a 13 year old LT. so fixing one this old is dicey.
  • (reason is XP is dead OS and parts hard to find)
  • why look for fuses. if a fuse works on 1 boot why would it fail 2nd boot? answer its not a fuse its dream of a fuse. (hope)
  • Does BIOS screens work,
  • Does using a DT screen on the rear 15p, VGA port work can the external screen be made to work.
  • Does booting to any bootable CD work, HP windows install or live LINUX cd, or window live PE CD work. if yes the LT is ok
  • just has bad OS or BAD HDD.
  • Power dead totally and 19vdc on the MOBO input pins
  • is a dead mobo, no BIOS,on both screens, 19vdc in is a dead mobo. The fuse if present are SMD fuses F1,F1, if mobo marked, L1, L2, those are inductors not fuse... nice try though.
http://jeepdied.com/look/puters/dead-screen.html
Posted on Apr 04, 2017
3 Suggested Answers
SOURCE:
sodeep
  • 3267 Answers
SOURCE: i had a GPU issue
While opening the laptop, dust/moisture may have accumulated on the contact points to the battery, hence LED is lighting up since power is reaching till there but does not continue to the battery. Another soln is to keep the laptop operating on the battery till the battery is completely drained of charge. Remove the battery for a couple of hours & after cleaning the battery connection points replace & switch on the AC adapter & check the battery charge without using the laptop to see if the charge has gone up or not, else the battery could be a fake( or Chinese) ...........sodeep
Posted on Aug 20, 2009
  • 33 Answers
SOURCE: HP Compaq laptop won't charge/power from AC due to blown fuse
There's plenty of causes why your laptop would not power up from the AC adapter and won't charge the battery. Here are some possible causes and solutions to this problem:
Number one, if it's on battery power, the battery is dead or the battery is bad and number two the AC adapter could be bad. Let's roll out number one.
1. Take out the battery, remove main supply, hold power button down for 30 seconds. This will drain the charges in your
battery. Put only power supply in, do not put battery in, turn laptop on, put the battery in.
2. If the solution in no.1 doesn't solve the problem, pull the battery out, keep the battery out of the laptop for this test.
Take your AC adapter and check the voltage with a voltmeter. What you want to test for is voltage. Put the meter at 20
volts DC and take the tip, the power jack tip of your AC power adapter. You hold the black, (the negative part) of your
voltmeter on the outside of the power jack tip of your AC adapter and you put the red (the positive part) of your voltmeter
in the hole in the inside of the power jack tip of your AC adapter. Be very careful not to touch the red and the black part of
your multimeter and the power jack tips of your AC adapter together, otherwise it will create a short circuit.
After doing these procedures, if your AC adapter is good it will output a voltage which ranges from 18 to 19V DC on your
voltmeter, depending on the voltage that puts out on your AC power adapter. If your voltmeter doesn't show any voltage,
probably your AC power adapter is bad or damaged. But if your voltmeter shows up voltage, then we have to go to the
next possible cause why your laptop won't power on.
3. The dc jack on your laptop might be bad, if the dc jack on your laptop is bad or not making a connection to the
motherboard then it look the battery is bad as well, because the battery is now not holding a charge or even taking a
charge. Also, even if your AC power adapter is good and when you insert it to the dc jack in your laptop it could not power
up the laptop because the dc jack is not making a connection to your laptop motherboard in other words the dc jack might
got loose, that's why it's not making any connection to the motherboard. The only way to solve this is that you have to
disassemble your laptop, and take the laptop motherboard out and look where the dc jack is connected. After you found it,
take a file tool and file off a spot on the motherboard where you can reattach the power jack and use a wire to reattach
the power jack to the motherboard.
Hope you find this answer helpful. God bless.
http://compunics.blogspot.com/2010/06/podnutz-high-definition-laptop-repair.html
Posted on Jun 23, 2010
Compaq evo n1015v will not boot up when power is pressed
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-compaq-evo-n1015v-ac-adapter-90watt.html
Dec 18, 2012 | HP Compaq Evo Notebook N1015v (470046-573)
If i plug an ac adapter 19 volts 4.7amperes to my compaq evo n610c, will it broke
YES - the N610c uses hp power pack 402018-001 18.5vlts 3.5amp 65W 50/60hz -
Jun 16, 2010 | HP Compaq Evo n610c Notebook
My compaq evo d510 cmt keyboard lights flashing constantly
first problem its a compaq go buy something else no seriously buy something else
check your bios settings F10 for compaq if i remember corectly might be F2
http://h18000.www1.hp.com/products/quickspecs/11349_na/11349_na.HTML
http://reviews.cnet.com/desktops/hp-compaq-evo-d510/1707-3118_7-20719364.html
i mean com on 533 bus and dosnt saport multi core cpu's
my 2004 dell 200 mhz buss saports quad core wth
if its not a bios setting replace your keyboard good luck
Feb 19, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Compaq Evo doesnt turn on.
When you plug the laptop to the power adapter, you should see the indicator led lit up telling that it has good connection to the ac adaptor. It wont turn on because either there is a loose connection to the power adaptor and hasn't been charging the battery, or the power adaptor itself is bad. Check the power plug with a miltimeter, it should be around 19 Volts.
Jul 02, 2009 | Compaq Evo N610C Notebook
Fuse in laptop
Normally the fuse rating is stamped on the end caps of the fuse. It would be rated in amps. Just get one that has the same rating and length.
The fuse will be held in place by spring clips that clip on the end caps of the fuse. Look for these clips, they will fit nearly onto the metal caps of the fuse.
May 26, 2009 | Compaq Computers & Internet
Compaq EVO 610 startup
replaced mainboard solved.....
May 06, 2008 | Compaq Evo N610C Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
Compaq EVO N400C PC Notebook Problem brought new battery! fully charged all night! turn laptop on within one second the thing turns off! AC works fine! new battery! old laptop! what can i do, please help?
your laptop should function even without a battery. Remove the battery you just bought and see if only with AC adapter, would your laptop turn on?
If not, then try removing the memory and see using a pencil eraser, clean the contacts of the memory and see if you can power your laptop with only ac
Apr 05, 2008 | Compaq Evo N400C Notebook
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
HP Compaq Motherboard Logo
134 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
