Question about Wolfgang Puck Salt & Pepper Mill Set
Salt won't come out...top twisted too hard
The top of the salt mill was twisted too hard and now nothing will come out. I can not seem to figure out what is jammed but it seems something is.
How do I get the mill open to fill it and put in batteries?
d65b8aa2-bda9-4fd2-810b-bf61e63e797e.jpg pepper mill
e206c9bf-aafd-400c-9672-b16614dd71b0.jpg Unscrew top where clear part attaches to metal. 55cea22b-5cf2-484e-9228-41c8146cea32.jpg
To load batteries, unscrew bottom. Once open, load fresh batteries. If mill fails to operate, unscrew bottom again and flip wire bale in opposite direction.
Jul 05, 2014 | Wolfgang Puck Salt & Pepper Mill Set
Tip
How to Open to refill a Reusable Acrylic Pepper & Salt Mill
Hello. This is about opening an acrylic pepper and salt mill or pepper grinder so that you may refill this kitchen utensil. One will usually find that the chrome knob on top of the pepper mill is used to open the pepper mill can be too difficult to open, because one cannot grip the chrome knob on top of the pepper mill to open. I am going to offer three different options for opening a pepper mill:
1) Use a pair of work gloves with specialize dripping material on finger tips. Hold top bulb while turning chrome knob counter clockwise.
2) A small nut wrench with cellophane tape on chrome knob to above marring chrome knob.
3) Get a wrench and a towel. Fit folded towel in jaws of wrench and place towel and open wrench on chrome knob and turn counter clockwise. Practice on a pine dowel to know appropriate pressure to use to avoid marring the chrome knob. If you can replace the chrome smooth knob with a grip friendly knob, if possible.
Finally, do not over tighten knob just finger tight.
on Feb 28, 2017 | Kitchen Appliances - Others
How do I fill with pepper
On most pepper mills, some part of the upper half usually unscrews, and the 'top' and 'bottom' can be separated. The bottom part will have a 'reservoir' in which the peppercorns should be placed, to eventually be ground.
Apr 05, 2014 | Bodum The Furniture Store Bistro Automatic...
Have all in one electronic Wolfgang puck salt and pepper mill. I can't figure out hot to open the top to replace the batteries. It does not work like the electronic sets (is a bit different).
batteries are in the bottom. unscrew bottom cap and pull metal ring to release battery pack. put in fresh batteries and return to casing. screw cap in place. if it does not work immediately, unscrew cap again and move metal wire to opposite side of battery pack and replace the cap again.
Oct 13, 2013 | Wolfgang Puck Salt & Pepper Mill Set
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
I received a se of Russell Hobbs Salt & Pepper Mills as a Christmas gift. But after only 4.1/2 months the salt mill doesn't work. I have replaced the batteries, swapped the head from the pepper mill,...
Hi Lorraine.
You'll need to talk to Salton Appliances in Melbourne. They are the Australian importer for Russell Hobbs.
Phone: 1800 427 842
Email: info@salton.com.au
BTW This is not their direct site so I recommend you delete all of your personal contact info from here.
Regards from Nowra :)
May 21, 2010 | Kitchen Appliances - Others
Wolfgang Puck Salt & Pepper Mill Set Logo
154 people viewed this question
Top Wolfgang Puck Home Experts
john h
Tom Chichester
Are you a Wolfgang Puck Home Expert? Answer questions, earn points and help others
