Question about Husqvarna Garden
Edger blade not turning
Brand new Husky trimmer / edger , used 2 minutes blade on edger stopped turning
  • 313 Answers
SOURCE: Black and Decker st4000 CORDED electric trimmer/edger
no fuse in this unit. checked first the switch terminal then the motor connetion. could be brushes.
Posted on Jun 02, 2008
  • 313 Answers
SOURCE: CST2000 Grass Hog Cordless Trimmer/Edger stops working until shaken
open up the motor housing maybe loose connection between the terminal & motor. for parts & diagram see www.dewaltservcienet.com look for the icon find it now & enter the model #
Posted on Jul 26, 2008
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
SOURCE: Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Posted on Jul 25, 2009
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Cultivator spinning slow
If the blades are turning slowly while the machine is on tick-over, then it is more than likely a clutch issue. Clutch springs will stretch and occasionally break. With less resistance on the clutch shoes they grip the clutch drum and this in-turn will cause the blades to turn.
Check clutch springs.
Apr 10, 2013 | Stihl Garden
No spark
Mag. failure on husky`s is quite common, l had a similar problem with my husky chainsaw.l would on your`s try another spark plug first then check the mag....
Dec 31, 2012 | Husqvarna 28cc 2-Cycle Curved-Shaft Gas...
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Describe your Black & Decker
Take the casing apart and I bet one of the wires for the cord pulled out. I bought a brand new ryobi sawsall,used it ten minutes and it quit. Was going to throw it away but decided to open the casing and the black wire pulled out of the terminal,it was a five minute fix swear to God!
Aug 10, 2009 | Black & Decker 14" Grass Hog Xp...
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
Jun 13, 2009 | Ryobi Garden
How to change an old edger blade
Apr 09, 2009 | Garden
Garden Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
