Question about NitroRCX.com Iron track rc bowie 1:10 scale 4wd brushless truck almost ready to run
When I try to drive my iron track bowie 1:10 scale it slows down and the tires on it stalls..
Tires are stalling
Whats making my 1999 mercury sable make a loud roaring sound while driving? and sometimes it stalls when stopping or slowing down.
Used tires sometimes are used for a reason. Also make sure your brakes are releasing completely (especially the emergency brake)...sometimes over-tightening wheels on to the disc brakes can cause excessive noise.
Feb 02, 2015 | 1999 Mercury Sable
My 2005 infinity has all of a sudden thrown me 3 different lights. Service engine soon, vdc off, and slip. I recently had a flat and got a used tire put on. The car stalls to start and is now cutting off...
Your tire sensors are sensing different size tires./ Your tires are rotating at different speeds because of the size difference. put the same tires on the front axle if front wheel drive. and the same tires on the rear if rear wheel drive. be sure to match tire pressure.
Aug 03, 2014 | Cars & Trucks
My 1996 Jeep Grand Cherokee loses power and stalls when going up a steep hill on the freeway. It also several times the steering wheel has violently shaken when I hit a bump in the road. It almost felt...
You have two unrelated problems. the power loss can be from a variety of things. What you first need to do with that is have a scan done (many parts stores do that free)...then if you have codes stored, you at least have some direction to go in with that.
The shaking is called death wobble and also has many causes. The most common are bad ball joints or tires that are worn sufficiently so as to not have enough foreward momentum to not react to side loading from bumps. The same tire can still generally pass inspection but is no longer useful on your vehicle (usually with around two thirty seconds of remaining tread measured at the wear bars). Any wear in any of the front end steering components or bushings can also cause wobble...sometimes it is a cumulative effect of slight wear in several places totaling an unacceptable amount of overall play. If you just had brake work or new tires installed, sometimes improper torquing of the wheels can also cause that. If you don't see anything obvious have an experienced jeep tech look at it. It can be dangerous and is nothing to ignore or wait on.
Nov 10, 2010 | 1996 Jeep Grand Cherokee
Help please!
very possible a vacuum leak somewhere.
Nov 30, 2009 | 1999 Chevrolet Monte Carlo
After filling 06 300c with fuel it stalls repeatedly then runs ok
Check the charcoal canister vent or filler tube vent to see if it.s plugged
Sep 09, 2009 | 2006 Chrysler 300
Right rear axel makes noise
You need to jack it up, And put it on jack stands. Its a safty thing. Next spin the tires with the engine, Put it in drive. let the Brake off slow. Don't forget to block the front tires with a brick, or a 4x4 or 2 pieces of fire wood. Put one under each front tire. Now run the engine 30 to 35 miles per hour.With the tires still on your Rover. Pay close attn to the noise as the tires spin. Now pull the wheels and pull the rotor or drum off. Now if its a bearing you will here it. Be sure to let off the gas pedal very slowly so you won't hurt the drive train. We checked wheel balance, Wheel bearings, Brake noise, even out of round tires can be spoted while running the tires on and off to do the test. its like driving it down the road but you can get down there and look and hear things. I sure hope this is helpfull to you.
Aug 18, 2009 | 1999 Land Rover Range Rover
Car wants to stall while driving
Check for trouble codes first thing, It could be a number of things. example, mass air flow sensor, map sensor, crank sensor, ignition module. Check for codes first to see if there are any. That will help you get on the right track
Jul 26, 2009 | 1991 Oldsmobile Cutlass Ciera
Rough idel , cuts out while in drive , stalls ,engine skip
Take the car to a garage that has a computer. I had the same problem and it turned out to be the idler solenoid that is located on top of the engine on the fuel injector port. The computer will diagnose the problem in a short time.
Jan 21, 2009 | 1994 Buick LeSabre
Turning problems
My Answer:
The one thing you never mentioned was if you had your Jeep SUV Front-end Aligned after you had the new tires installed?
I'm guessing/hoping you did???
Where did you have the work done at? Be specific here!
Was it a 2-wheel or 4-wheel alignment if that applies here? Big difference it was done RIGHT or if it was done WRONG? That's just maybe part of the problem though if it was indeed MIS-ALIGNED. When you say PULLING - that is a BIG CLUE right there of a possible MIS-ALIGNMENT!!
Not sure what size tires you had on it originally or which size new tires you had put on, but if the new tires were over-sized then you are rubbing on the mainframe or possibly rubbing the front fender wells??
This has happened before, as sometimes they don't pull the right size tires from stock, and then don't double check them before mounting them.
Esp when you are running bigger rims and lower profile tires, which might be your case, as you didn't say anything to the contrary.
If we're talking about STOCK tires for STOCK tires here then your driver side door decal will state the factory installed tires as to their proper size. Any modification to that as to bigger rims and lower profile tires has to be done to factory recommended specs. Lets hope so anyway!
If I were you I would be double checking everything, as to what was actually done, and as to what tires, etc were put on your SUV.
The clue to your problem lies right there to start with! After all nothing was mentioned about any "pulling" before you had the new tires put on.
Here's one last big clue as to if you actually got a "bad alignment" on your Jeep SUV.
Have someone else drive behind you on an empty straight flat street (or else have someone else drive your Jeep and you follow behind about 4 to 5 car lengths back). If your Jeep's body is trying to track crooked (as if on an angle diagonal to straight ahead) as the tires are trying to track straight ahead - then you definitely just got a bummer mis-alignment!
I'm putting my money this is the case, as I've seen it so many times it's not funny.
It called a "shade tree alignment" and for good reason.
Let me know I was right?
Frank
Jun 25, 2008 | 2003 Jeep Grand Cherokee
NitroRCX.com Iron track rc bowie 1:10 scale 4wd brushless truck almost ready to run Logo
27 people viewed this question
Top NitroRCX.com Electronics - Others Experts
Are you a NitroRCX.com Electronics - Other Expert? Answer questions, earn points and help others
