Question about Danby DWC283BLS Wine Cooler
Danby wine cooler run activation light not on
Run activation light not on
  • 1073 Answers
SOURCE: Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Posted on Apr 12, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
huuum
  • 750 Answers
SOURCE: E4 Code
Dear moriquenda
welcome to fixya.
Did you try resetting the system by pulling the plug and waiting 5 minutes then restarting the wine cooler?This may solve you problem.
Danby expects customers to call service and does not imagine the rest of the world being able to utilize these codes.
Closed minded, Huh?
Please remember to leave a rating!
Huuum
Posted on Sep 28, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
  • 15 Answers
SOURCE: My Danby wine cooler makes
check the fan near the motor or inside it this kind of wine cooler always have fan problem
Posted on Sep 11, 2010
I have outdoor security lights that run on a timer. Are there some that use a motion detector?
Yes, in fact most people have motion-detector activated lighting so they can know if there is suspicious activity outside of their home. Many security companies also offer systems that allow you to operate the lighting at your home from a smartphone or personal computer, which can help save electricity when it comes to outdoor lighting.
May 09, 2013 | Home Security
My running lights arent working for trailor lights
The running lights just for the front, to activate the tail lights you have turn on the switch
Mar 28, 2013 | Cars & Trucks
How do i dim all my interior lights with the headlights off in my 2011 dodge charger
There should be an adjustment knob just to the left of the steering column that will adjust the brightness of the dash lights. The problem you will have is the Dash lights only activate when the parking lights or headlights are on with the switch unless you have automatic running lights which will activate the dash lights when the running lights activate.
Aug 28, 2011 | Dodge Charger Cars & Trucks
How do I implement Daytime Running lights on a MDX? I am importing it to Canada and require DRLs.
install a relay from the ignition switch to the headlights so when ignition switch is ON the relay is activated which activates the Light switch or just straight to the Headlights
Jan 01, 2010 | 2002 Acura MDX
The headlights do not activate automatically, in the auto mode, at night or with minimal daylight. However the running lights will activate in the auto mode. A new dash light switch was installed without...
The light sensor to control the automatic headlamps is located on the dashboard. This sensor is suppose to activate running and headlamps. I would suspect the problem is a relay to operate the headlamps if the car uses a seperate relay in the automatic mode. I'm assuming the headlamps work in manual on/off. FYI... The auto mode does not control the fog lamps.
Nov 15, 2009 | 2001 Mercury Sable
Danby DWC283BLS Wine Cooler Logo
143 people viewed this question
Top Danby Furniture Experts
Charles T Nevin
Charles T Nevin
Dennis Boxerman
christian nielsen
Are you a Danby Furniture Expert? Answer questions, earn points and help others
