Question about Lionel Train Lionel Lines Burro Crane 3360 Car 6-28414
Rigging the cable for the burro crane #3360
Hook needs to be re threaded
How do I remove the engine from a Toyota Camry LE 2004?
Undo the wiring, hoses drive shafts unbolt the engine mounts disconnect the speedo and gear shift cables and cooler pipes if auto obtain an engine crane hook up to the lift hooks at either end of the motor ,then lift the lot out of the car.
Apr 28, 2015 | Toyota Camry Cars & Trucks
2001 olds aurora 3.5l engine removal
Remove the bonnet, drain oil and water remove radiator and fan remove all hoses cables and wiring attached to the engine. take weight of engine with a floor crane support the transmission .uncouple transmission from engine remove engine mount bolts , take a little more weight with the crane and slide engine clear of transmission , lift clear of car and slide crane clear to engine stand.
Dec 25, 2014 | 2001 Oldsmobile Aurora
Need wiring diagram for lionel 165
Magnet is connected to one3 terminal on the rotating base of the crane and 2 the connector that presses onto the top of the spool that the line for the hook attaches to. Note when the magnet is activated, the red light in the crane cab lights up.
Nov 28, 2013 | Toys
How to hook up my home theater so i can listen to my mp3 player
I don't have a picture but you probably need a Stereo 1/8" Mini to RCA patch cable. If you go to radioshack.com, search for 15-2474 and they have a picture of the cable you should need. The cable is "high quality" made by Monster and is only $4.97. To be safe, take your MP3 player to the store in case is has an "odd ball" jack instead of the 1/8" Mini which is pretty standard now. Connect the other end with the (2) RCA plugs to one of the available inputs on the back of your home-theater rig (i.e. AUX IN, MD/TAPE IN, etc.). If your MP3 player has a volume control, set the output to about half. Then, select the corresponding input on the home-theater rig and you should be good to go. Now you can control the speaker level with either the MP3's volume control or the master-volume control on the rig.
Mar 29, 2013 | Audio Players & Recorders
Satellite in outlet is broken off.
You've only gave me 3 seconds to make a conclusion..now really? It looks like it could be the yellow cable but again it just looks like it is just sticking up there??? I tell ya what...if you want to try RIG it rather than taking it to a shop. Go get some J-B Weld at a Auto store. Buy the stuff that takes 4-6 hours before handeling and overnight before putting into use. Get a knife and scratch the area around the connection so as to make a good place for the stuff to grip to. Just don't get it into the the threads that will keep you from making use of the cable. Now this is rigging it, not a really correct way, but if you have enough sticking out of the case, it will work!
Feb 15, 2013 | Televison & Video
Need to know how to use it?
Here's the link where you can download the manual, which will have everything you need to know about cleaning it and maintaining it:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
May 28, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
How do I Insert new sims card
Some 3360 and other models were manufactured for different markets and some of these markets didnt had the SIM card technology by the time this phone was released so:
Some 3360 dont use SIM and may not work on your cellhone provider.
Try asking your provider to see if you can activate the phone without SIM as some providers usually offered the service in the transition between technologies and standards.
Good Luck...
Sep 01, 2007 | Nokia 3360
Lionel Train Lionel Lines Burro Crane 3360 Car 6-28414 Logo
29 people viewed this question
Top Lionel Crafts & Hobbies Experts
Tom Chichester
freddyfox
J.D. Browning
J.D. Browning
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
