Paragon 2018 Pro Style Butter Warmer Logo
A
Anonymous Posted on Feb 09, 2014
Suction does not work
The butter warmer suction does not function appropriately and will not dispense butter. we have three and all have crapped out with the same issue.
Alan Strauss
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 24, 2015
Alan Strauss
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1120
Points
I had the same issue. What I discovered is that when the pump removes the butter it creates a vacume inside the butter vessel. the pump has a hard time overcomming the created vacume. I have drilled an 1/8" hole in the top to allow air to replace the removed butter.
Hi my mixer suddenly stopped when i was working on it. The butter i was beating was kinda hard is that a reason it stopped?
Does the mixer not turn on at all or the beater just wont turn? Depending on the mixer it could have a fuse that shuts the mixer off if over heated, but it could also be gears.
If you can get the model off of the bottom of the mixer, and then give a bit more information on how it is not working then we can help you with the repair.
Also yes, the butter would most likely be the reason the mixer stopped working. You are supposed to use butter that is soft & at room temperature. I find that if you are in a rush or forgot to soften the butter you can cut it up into small slices and then cream it in your mixer and it doesn't strip the gears.
-Colleen@MendingShed
Apr 16, 2015 • Food Mixers
GE Profile refrigerator model PFSS6KW/PFSF6PKW not making ice.
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Why is my GE profile fridge no longer dispensing ice? Can I fix this myself or do I need a professional.
  1. Dispenser control board If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  2. Water inlet valve & low water pressure from house supply If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  3. Water tube in door is frozen If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  4. Dispenser switch If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  5. Door switch If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Search Over 2 1 Million Appliance Parts
GE profile refrigerator ice maker not working
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Paragon 2018 warmer will not pump cheese
That is a Butter pump, it is not designed to pump cheese. They are very different liquids.
http://www.manufacturedfun.com/documents/support/17af41375978991806.pdf
Wha is a warmer
A warmer can mean two things when considering a refrigerator. The first will be a evaporator core warmer or heater. This device is essentially an element that keeps ice from forming on the core. It is controlled by a defrost timer and a thermostat. Once the timer reaches a set interval, it will initiate the warmer/heater to defrost the evaporator core. This mechanism will keep the core free of ice, which in return, keeps the unit operating as designed. The second type of "warmer" is a water line warmer or heater. This is a thin copper or steel line that is wrapped around the inlet lines inside your unit. This type of warmer/heater keeps the inlet lines from freezing over inside the unit. If the line freezes, they cant transfer water to the dispenser and ice maker. This style of warmer prevent s these important lines from freezing over.
Additionally; some side by side units have divider warmers to keep the condensation down that can form in the summer months. This type of warmer is mounted inside the frame, near the divider, and is an automatic functioning device.
3answers
AEG Santos S83168KD1 - The lock light of the water dispenser flashes after the water filter leaked inside the refrigerator. I have dried the refrigerator and replaced the filter but the light is still...
The indicator lamp can be switched off by holding the button for ordinary water (K) pressed in for about three seconds until the indicator lamp goes out. Click on the link below to download the AEG Santos S83168KD1 user manual
http://safemanuals.com/314159.php?k=5311c849edaf9949b74f80cd1a089035&ID=421951&q=AEG-ELECTROLUX S83168KD1
1helpful
Exterior water function stopped working. This is simultaneous with me removing the ice holder to defrost, then replacing. Ice maker functions and all else seems normal.  It seems like water and ice...
ck the fresh food tempt it may be too cold . and has frozen water line . adjust to a warmer tempt and it should start working .. mm ps in 24 hr or so ..
Butter warmer problem
The problem for Butter warmer not working was as I suspected the internal workings of the regulator slider that adjusts the temp for the butter warmer it's self. The regulator intenals get a sort of burnt ember on them from something similar to a couple of positive and negative wires connecting causing a sorf of short. I have an electrical tech nearby who opened up the regulator to find and use a small wire brush and scraper removed the burnt on gum. It returned the warmer to working immediately upon re-installation and is still several years later, working a treat.
I am disappointed to note that in stores we have checked to upgrade our fridge all say that no models have the butter warmer anymore. Hence we are holding on to our fridge.
Top Paragon Kitchen Appliances - Others Experts
john h
Are you a Paragon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
