Question about NEC AccuSync LCD71VM 17" LCD Monitor
NEC Monitor LCD1700V
The monitor screen goes blank after less than 5 seconds.
  • 2 more comments
  • Anonymous Nov 15, 2007
    when the computer is turned on, windows starts loading and the monitor turns black. when windows finish loading and you push the monitors start button, you see the start screen briefly and it turns black
  • Anonymous Nov 27, 2007
    I have the same exact problem... monitor screen comes on but then blacks out after less than 5 seconds
  • kyla130 Dec 23, 2007
    I have the same problem - I can't even get into the screen settings as the screen blacks out too quickly!
  • gouldianguy Feb 12, 2008
    I have nec 1810 turns on then fades out-when window are opening it turns on the turns black-any ideas?
I had a similar problem with a NEC LCD1935, and I traced it to the inverter board which was a Lien Chang LI-2190 ... it seems that common problems with this type of board are bad solder joints due to the temp. cycling, or blown capacitors, but I was too lazy to resolder everything so I just disconnected the BL signal line that goes between the main board and the inverter board, and this solved the problem. In my display it was a green line, marked BL on the inverter board -- I removed it from the connector and just taped it off.  I'm guessing that this is a blanking signal that the invertor uses to signal to the main board there is an overcurrent situation and that the display should be blanked/shutdown.
I'm certain that there are still problems with the inverter and it might go again, but at least I have a working monitor for the time being.
Caveat emptor.
Posted on Dec 17, 2008
I have a NEC Accusync LCD52V, I got the same problem. I solve this problem removing pin 4 from CN201 connector located in the "VGA" controller board (board p/n 715G-1350-3-GM). I just took out the connector and insulate it.
Posted on Oct 01, 2009
  • 22 Answers
Either the internal power supply unit or the backlight inverter has failed. If you look really closely at the screen after it shuts off, if you can still see something moving on the screen (eg, your mouse) then the backlight needs to be replaced. If it is completely blank, the power supply needs to be replaced.
This repair is difficult and can only be done by a technician.
Posted on Sep 09, 2008
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
Nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem
Mar 05, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
My monitor not stay on
Very common for this model that top backlight globe goes faulty. Can be also inverter PCB fault. If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
Mar 28, 2006 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC AccuSync LCD71VM 17" LCD Monitor Logo
397 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
