Question about Nordic Track NordicTrack - GX 2.5
Replace resistance motor nordictrack gx2.5 - Nordic Track NordicTrack - GX 2.5
Just bought a nordictrack audio strider 900 every thing works OK a part from the resistance . Go to alter resistance and nothing changes Any ideas as to why Kind regards nick
the resistance is done by a magnet and a motor that moves it closer or farther away from the flywheel. possible the motor is bad or not adjusted properly
Jan 30, 2016 | NordicTrack Exercise & Fitness
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Why can we only peddle backwards. When we peddle forward, there is too much resistance.
Your resistance motor can be bad, the magnets are full expanded and stopping the forward movement.. You need a crank remover to take the body covers off to inspect the resistance motor.
Mar 01, 2015 | Nordic Track NordicTrack - GX 2.5
Nordictrack cx 1055 There is No Resistance. It used to take several seconds to get resistance. But now the resistance is Zero. The Ramp raises and lowers just fine. Is there a video somewhere showi
Sounds like a small control board may have died, more specifically, a failed capacitor or such. Resistance is often achieved by pulsing an "eddy current" brake driven by a transistor, or draining a generator charge electrically, which are attached to a central crank, which stiffens the torque required to rotate and the user sees this as a increase in resistance :-) you can always contact jatinah electronics for further help.
Feb 02, 2015 | Nordic Track Nordictrack Cx1055 Elliptical...
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
Nordictrack cx 1055 resistance stuck
Need a new elevation motor 1-888-308-9620
Dec 19, 2013 | Exercise & Fitness
NordicTrack Classic Pro Skier has a noisy pulley
1) LUBE the deck belt inmediately, maybe you have now a WORN deck belt time to replace.
2) LUBE the rollers bearing TOO.
3) test the voltage input motor, if there are the motor NEED repair
God bless you
Oct 14, 2012 | Nordic Track NordicTrack Classic Pro Skier
Nordictrack auidostridder 800 elliptical screen dead
Chad Gilbert--
I'm having the same problem with my Audiostrider 800. Fan works, screen and soft buttons do nothing.
I dont mean to sound dumb, but where are these motor brushes? Are they attached to the resistance motor or somewhere else? What exactly am I looking for?
Any help would be greatly appreciated!!
Aug 11, 2012 | Nordic Track Nordictrack Audiostrider 800...
Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Jun 10, 2012 | Exercise & Fitness
We have a Nordictrack Futura 2200 and when we set the weight resistance it jumps back to 10lbs. no matter what we set it for it jumps back to 10lbs
When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If the motor has difficulty adjusting the resistance level and no cable is being pulled, there may be too much tension on the Upper Cable (110). Adjust the tension as described below. To decrease the tension on the Upper Cable (110), turn the two 3/8” x 38mm Tension Screws (106) twice, counterclockwise. Select the desired resistance setting. Repeat this step if necessary.
Apr 24, 2010 | Nordic Track Nordictrack Futura 2200...
Nordic Track NordicTrack - GX 2.5 Logo
128 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
