Question about Plumbing
Kohler k 12171 can't remove faucet handle. I removed the screw and am now stuck.
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 34 Answers
SOURCE: Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: How do I get the cartridge out of Kohler kitchen faucet Coralais
You have to remove the "large" nut but you need to find a way to hold the faucet. Also, you will see a retaining washer that fits on the inside of that "large" nut. If you loosen this it will release some of the tention on it and hopefull make it easier to remove. Also, try using some lime remover on the unit will might alow the retaining nut to loosen. Good luck and if you can't get it off, contact Kohler, they have an 800 number and they can give you the info you will need depending on your model.
Posted on Mar 30, 2009
  • 235 Answers
SOURCE: The faucet handle has become stiff to turn off and
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Posted on Jul 05, 2009
  • 297 Answers
SOURCE: Replacing the ceramic valve in the handle, how do you remove it?
it has a screw down cap on top of the valve.counterclock wise.then pull straight up on valve. if you twist the supply line while doing this disconnect the line first then work on valve.
Posted on Jul 15, 2009
How do I remove the handle for this Kohler R780-VS faucet? I have already removed the screw that I thought was holding it in but it won't come off.
For some of these faucets, removal of the allen set screw is only the beginning of the process. The handle may be stuck on the stem and if a handle remover can't be used (yes, there is such a tool!), it will take some gentle persuasion by tapping with a SOFT mallet and wiggling to get results.
Oct 09, 2016 | Kohler Plumbing
How do I get the faucet apart on kohler Fairview k-12171 faucet
put a picture of it in and perhaps I can assist
Feb 13, 2015 | Kohler Plumbing
How to remove the handle from a kohler faucet?
Once the screw is out, simple pry out the handle. The older the faucet, the more it gets set in place. You may have to use a wedge in the space between the handle and the faucet to loosen it. Be careful to not damage the finish, especially if you want to re-use the faucet.
Aug 05, 2014 | Kohler K-12176-PB Fairfax Single Handle...
How do you remove the lever of a kitchen kohler clairette faucet, it seems to be stuck
On the front of the faucet handle, there is a small plastic cover with an emblem on it. Gently pry it off with a sharp knife blade. Next you will notice a small "allen" screw head. Remove it by turning it counter clockwise until it's loose. (lefty loosie - righty tighty) Lift the handle straight up to remove.
Jun 23, 2014 | Kohler K-15160-7 Coralais single-control...
Kohler k 12171 how do I remove the handle
Lift up the top cap (plug button) and you will see the screw.
If you need further information, download the installation guide from this link:
http://www.faucet.com/mediabase/specifications/1004617_2.pdf
Page 6 shows the exploded diagram of the handle.
Feb 09, 2014 | Plumbing
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
How to take the faucet hander off
Remove the cap and expose the screw. Unscrew and remove handle. If it is stuck on you can buy a faucet handle puller at any hardware store for 8 - 15 dollars.
Dec 24, 2010 | Kohler Efficiency Kitchen Sink Drop In...
Kohler fairfax k12175 cp took out button plug and screw - lever handle and bonnet won't come out - how do I get them out
Place a few drops of vinegar into the screw hole and wait a little bit. Try removing the handle again, sounds like it is just stuck on the cartridge stem. The handle should come off first, and then the bonnet. Here's the parts breakdown for your faucet from Kohler.
Sep 07, 2010 | Kohler Plumbing
Hot water handle hard to turn.
depends on which model faucet you have...
some handles are removed by removing a screw in the top of the handle hidden under a small decoritive cap
some handles are removed be removing a set screw using an allen wrench in the side of the handle usually under a small rubber plug
Jul 07, 2010 | Kohler K-16102-4-AF Revival Widespread...
Need to dissasemble the faucet...
Go to http://www.kohlerserviceparts.kohler.com/ and get a parts explosion for your faucet. It should help immensly.
May 29, 2010 | Kohler K-15076-P-7 Coralais Decorator...
Plumbing Logo
29 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
