Question about Fineline Settings 2516WH Full Size Extra Heavy Forks Boxed-1200 p
1991 gmc sierra 1500 350 engine will not heat and temperature guage barely will register
  • 7 Answers
Your thermostat has malfunctioned and is stuck open. This is a safety measure to prevent the engine from overheating in the case of failure. Change Thermostat and Gasket.
Posted on Mar 17, 2014
91 sierra heater control display comes on shoes fan on low temperature centered vent on floor but none of the controls work
Could be the controller. Check the vacuum line from the engine to vacuum ball. then from the ball to the controller. Vacuum is what controls the vent actuators.
Oct 30, 2016 | 1991 GMC Sierra
I have a 1998 gmc sierra 1500 that died when i gave it gas after putting it in gear. after it died i tried turning the ignition again and my guage read it was not charging but there was a buzzing sound...
First, check your alternator/serpentine belt for breakage/integrity. If you successfully re-started the engine after this incident, but your "volts" gage did not register as charging, your problem is likely alternator/belt-related.
Sep 26, 2013 | 1998 GMC Sierra
What is the engine size on a 1991 gmc sierra 2500 4x4
That year you probably have a 5.7 or 5.0 motor. You can find the engine size by getting your VIN and calling the dealer. They can tell you from either the 8th or 10th number in the VIN
Jan 29, 2012 | 1991 GMC Sierra
Help needed to figure out why truck says it over heating
you might want to check the wires going to the temperature sensor on the engine make sure it hasnt rubbed the protective coating off, this can give you a false reading, the safest way is to put a manual gauge in place of the temperature sensor and run engine to make sure the engine is not overheating. You can pick up a cheap manual temp gauge at your local parts store and install the temperature probe into the hole where the temp sensor was located and run the engine. It sounds like you have a guage malfunction. But is better to be safe than sorry.
Nov 16, 2011 | 1998 GMC Sierra
I have no heat in my truck. Temp gauge shows 180-210 degrees. What's the problem and where is the stat located on the engine. Is it under the alternator?
Hi:
If your truck temperature guage is reading 180-210, then your engine is at the right temperature, and your thermostat is fine. Most likely you have a problem with your heater core, which is located somewhat on the passenger side, under the dash. It is a small radiator, and if it doesnt have hot coolant circulating thru it, you wont get any heat.You could try to flush your cooling system, to see if you have any flow thru the heater core, but often you have to just change it. It can be quite a job to get to it, so make sure it is bad before you attempt repair.
Feb 06, 2010 | 2000 GMC Sierra
Where can i find the temperture switch on a 1986 gmc sierra truck
If you mean the sending unit for the temperature guage then you will fi nd it hiding below #1 plug and behind the exhaust manifold on a V-8.
Jul 11, 2009 | 1994 GMC Sierra
2004 GMC Sierra Heater does not heat on low RPM
check your coolant level on the radiator
Feb 03, 2009 | 2000 GMC New Sierra 1500
My 1990 gmc sierra 1500 temp. guage stuck after new thermostat.
Hi
Does your temp guage needle drop to Zero when you switch off ignition ?
If not, your temperature transmitter is faulty, or the wire running to it is earthing out somewhere.
Hope this is of help.
Good Luck !
John.
Jan 16, 2009 | 1990 GMC Sierra
1998 GMC Jimmy
sounds like the computer has a glitch. you might need to go to the dealer to have the computer trained(reprogrammed) or to see if you need a new one.
Aug 13, 2008 | 1998 GMC Jimmy
Fineline Settings 2516WH Full Size Extra Heavy Forks Boxed-1200 p Logo
551 people viewed this question
Top Fineline Settings Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Fineline Settings Retail Supply Expert? Answer questions, earn points and help others
