Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
How to decrease temperature in refrigerator
Too warm
A copper thin tube from the unit is very hot. Is it normal?
Yes, well somewhat normal. The refrigerant leaves the compressor at high temperature and flows through the condenser coil where it cools about 20 degrees warmer than the outside air flowing through the condenser. Many small air conditioner units use a small copper tube (capillary tube) of a specific diameter and length for that system to cause a decrease in refrigerant pressure between the condenser and the evaporator. The refrigerant leaves the compressor as a gas at high pressure, cools in the condenser and changes into a liquid. The liquid flows through the cap tube and cools more as the pressure decreases and gets closer to the evaporator. The refrigerant boils and evaporates under the low pressure of the evaporator and turns back into a gas. That gas is pulled back to the compressor.
If the condenser is not cooling the refrigerant enough, the tube can become extra hot. Efficiency is reduced. Actual temperatures throughout the system depend on the type refrigerant used, suction and discharge pressure at the compressor, outside and inside temperature. Tables, charts and graphs for various pressure-temperature relationships can be found in refrigeration books and chemical web sites.
Mar 17, 2015 | Carrier FB4ANF060 HVAC Electric Unit & AC...
How to set temperature on a general electric
Copied from ehow.com
Instructions
    • 1 Open the fresh food compartment and locate the two temperature control dials. Each dial is labeled for the compartment that it controls.
    • 2 Rotate the dial to increase the temperature setting by one to lower the temperature of the compartment. Rotate the dial to decrease the temperature setting by one to raise the temperature of the compartment.
    • 3 Wait 12 hours to allow the temperature in the compartment to stabilize before increasing or decreasing the temperature further.
Read more : http://www.ehow.com/how_8772966_adjust-temperature-controls-ge-refrigerator.html
Aug 28, 2014 | Refrigerators
Cant change the temperature
What is the complete model number of the unit?
Dec 03, 2012 | Refrigerators
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
To decrease the temperature do the numbers increase or decrease?
You need to decrease the number if you want it to be cooler. Change it on the temp control if you want to increase or decrease.
Thanks for asking.
Jun 23, 2011 | Refrigerators
The temperature continues to decrease and there is a buzzing sound (intermittant)
heatman101
Jun 02, 2011 | Jenn-Air JFC2089H Bottom Freezer French...
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a side by side that does not hold temperatures. It stays at zero then goes to 10 degresss than back to zero
That is normal operation. The temperature will increase when the compressor is off. When the compressor cycles on,the temperature will decrease.
Sep 28, 2009 | GE GSS25JFM Side by Side Refrigerator
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Jenn-Air JCD 2295 Refrigerator
I would say the cold control may be bad.If the fridge is getting too cold it sounds like the control is not shutting the unit down when it gets to temp. You can check the cold control with a OHM meter and see if it is working properly. If it is not you will need to replace it and your refrigerator should work fine.
Jul 15, 2007 | Jenn-Air JCD2290HES Side by Side...
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
14 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
