Question about Electrical Supplies
Huffy 5000 generator won't start - Electrical Supplies
2 Suggested Answers
chuckster57
  • 1102 Answers
SOURCE: I HAVN'T USED MY 5000
When you stored it, did you drain the fuel out of it or run it "dry"? If not then the gas has most likely turned to varnish and needs to be cleaned out. There is no real easy way to clean the junk out of the carb without taking it apart. You MIGHT get lucky if you put fresh gas in the tank and then use some starting fluid SPARINGLY and see if the new fuel might dissolve the residue.
Posted on Sep 11, 2011
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Centurion 5000 generator won't start after it sets for a month..why?
Maybe this article will be useful for you.
Why Diesel Generator Fail to Start
If you want to know more information about gas generator, this website will be useful for you. Gasoline Generator Set Gasoline Generator Data Supplier Exporter in China
May 23, 2012 | Electrical Supplies
I HAVE A POWERMATE 5000 12 hp GENERATOR THAT IS ABOUT 4 YEARS OLD. IT HAS BEEN IN STORAGE AND WON'T START NOW. I THINK IT MAY BE A CLOGGED CARBURATOR. WHERE DO I FIND THE SCHEMATICS OF HOW TO TAKE...
I have the same problem on my 10 hp if it set for a long time , I remove the spark plug and put a drop or 2 of gasoline in the cylinder and reinstall the plug and wite and it starts o the first pull
Sep 07, 2011 | Coleman Powermate Powermate 5000W...
Colman promate 5000 won't start, wher is teh fuel shut off valve?
on the bottom of the tank were the fuel line goes to the tank, it may be a round knob u turn, I have problems starting mine after setting a while so I choke it and pull the cord, if it has set for a long time, you may need to pull the spark plug and put a drop or 2 of gas in the cyilinder, reinstall the plug andwire and it should start.
Aug 27, 2011 | Coleman Powermate Powermate 5000W...
Huffy 5000 gen. started once after purchase then gas drain and gen stored. will not start now. new gas in tank, oil has been changed, spark at spark plug ( good not great) old gas drained from carb bowl,...
Hi men2cu...
Try this method, being you have spark and gas getting to the carburetor...
Get a can of starting fluid, and spray a small amount of it into the carburetor and then try to crank it again...if it cranks and runs then problem fixed...if it cranks and shuts off right away, then you have some trash in your inlet valve in your carburetor.
You can try tapping the carburetor lightly with a hammer and sometimes that will dislodge the float needle if it doesn't dislodge the needle valve then the carburetor will have to be disassemble and cleaned.
Once this is complete your generator should run fine.
Please take time to rate me
Aug 23, 2011 | Garden
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
