Question about HP ENVY 23-d065 TouchSmart All-in-One Desktop PC
No power to computer
Computer won't come on
Why won 't computer communicate with code checker
Check the cigarette lighter fuse. This is what powers the DLC. If the fuse is good, check and see if the lighter works. If not, you have a bad wire. Code readers have to have power from the car. Most scanners have there own power and will read the computer, unless the data wire is bad or the computer is bad.
Mar 28, 2015 | 1995 Buick LeSabre
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Ibuypower won't boot
Unplug the computer, Hold down the power button for 5 seconds.
Plug the computer in. Power on the computer.
Call, text or email Shane 801.554.4142 / rsownbey@msn.com
Apr 27, 2013 | Computers & Internet
There was a power outrage and now my computer won't turn on?
Check the source of power to your computer. Your computer should be plugged into a protection strip. Make sure that the protection strip reset button is reset. If that is ok, check the circuit breakers in the fuse box.
Jan 29, 2013 | Computers & Internet
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
Monitor says to check signal cable
get a new power cable for tower/computer. u can call i wat u want. new power cable for computer not moniter. or connection is incorrect. hope it helped.
Dec 05, 2011 | Samsung Computers & Internet
My compaq presario cq60 won,t turn on. the power light next to the charger cable is on but it won,t turn on
The charger is functioning well. There are still two possible reasons why your computer is not turning on. 1. The battery, 2. The computer itself.
What you need to do is to isolate the problem.
Here's what you can do to isolate the problem.
1. Remove the battery from the computer.
2. Turn on the computer using the cord. Remember not to put back the battery yet. Just the cable and the computer connected. If the computer turns on, then, you need to replace the battery.
3. If it still not turning on by using the cord alone. Try to wiggle the cord to check whether it's loose or not. Check if there are some signs of power on the computer. If there is a power like lights lit in the computer, then, it's the computer that's having the problem. You need to bring it to a technician if that's the situation.
Please let me know if there are any development after doing the troubleshooting above so that I can get back to you if you need my help.
Thank you for using fixya.com
CARLO
Apr 13, 2011 | Compaq Presario CQ60-220US PC Laptop
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
HP ENVY 23-d065 TouchSmart All-in-One Desktop PC Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
