I cant get a new cucle to start because its still flashing that its still doing an old cycle although there s nothing happening
3 Suggested Answers
  • 383 Answers
SOURCE: When it gets to spin
I did some research on F-11 codes and Vibration-- See if this helps:
The F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds.My research showed many people solving this problem with a replacement of the control unit or the relays inside of it.
The problem with the engineering and design of these washing machines was that they all vibrate excessively unless they are sitting on a floor constructed of a ton or more of solid concrete.
The vibration eventually makes either the motor serial/tach connector (or possibly one of the five relays in the control unit) intermittent, and the machine begins to throw error codes
I have found a good whack on the side of the machine seems to work. No kidding. Here's what happens: Stupid F11 flashes. I hit the pause/cancel button. It flashes the remaining time on the cycle. I hit the start button. Sometimes that just does it. If it doesn't I give it a whack on the left side of the machine, (if you're facing it), in the middle, about 6 to 8 inches above where the drawer is.
Let us know if we can help more--
Mack B
Posted on Jan 25, 2011
Daniel S
  • 4323 Answers
SOURCE: My Kelvinator Excellence only starts
Hi
The issue is with the control board that is bad and should be replaced. Hope this helps...please post back with the model no. for further assistance.
Daniel
Posted on May 18, 2011
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
I cant program my new scanner..
to program your channels. say start with #1 push prgm,type in the frequency number and press enter. repeat for each channel/ frequency
Apr 22, 2008 | Uniden BC340CRS Base Scanner
Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Feb 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher, not working
which 2 buttons flash?
Dec 05, 2007 | Dishwashers
Problem starting the camera, viewfinder LED just flashes one time.
chances are good that your camera needs to be formatted although they recommend that you do it from your camera and not from your computer
Aug 09, 2007 | Konica Revio C2 Digital Camera
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
