You press the lever no ice comes out
SOURCE: Whirlpool Gold Ice dispenser problem
i had same exact problem, i search over and over for solution. I even change the auger moter.
here is the solution for this particular problem.....
with the fridge door closed, remove bottom catch tray under ice dispenser revealing two screws, take off screws and slide front trim up to remove, you will have to unplug switch on trim to fully remove, look in top right corner there is black switch the will most likely be loose, this switch is your problem, mine was basically dislodged and the ice dispenser lever was not making contact, i simply zipped tied and siliconed the switch back to its respective place. if yours is making a good connection then the switch its self must be bad, you can test the switch by using the switch from water dispenser side...
i hope this helps
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
SOURCE: Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
