Question about Meade TeleStar 60AZ-A Telescope
DS-60 adjustable focus unit has "teeth" missing and can't be adjusted accurately
Item 16 on the parts list is what adjusts the focus item. Not sure if 17 on the parts list is it.
  • 55 Answers
SOURCE: Meade DS2102 Telescope lost teeth for focusing in and out
It might be easiest to see if someone is selling one on Craig's list or ebay.  You might be able to find one used where the telescope is OK, but the motorized drive is broken and replace the telescope.
Here is the contact information for Meade:
Contacting the Customer Support Center     Customer Support representatives are available to handle your calls and letters regarding any Meade product 7:00am to 5:00pm Pacific Standard Time, Monday through Friday, excluding holidays. To contact the Meade Customer Support Center, please write, call, or fax. Our information is as follows:
Meade Instruments Corporation
27 Hubble
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
You could try calling them and see if they will sell the part you need for the focuser.  The focuser is called a rack and pinion focuser.  From your description it is hard to know if it is the long linear gear on the draw-tube (the part that holds the eyepiece) or the gear on the shaft of the focusing knob.  You will need to be able to describe that to them.
I hope that helps.
Posted on May 06, 2009
SOURCE: The focal tube on my Meade DS 114 has several
You will need to buy another focuser like one of these.
http://www.telescope.com/control/accessories/telescope-focusers/1*25-inch-orion-basic-rack-and-pinion-focuser
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Posted on Feb 22, 2010
  • 152 Answers
SOURCE: .comMy Meade Polaris Telescope is
go to your local hardware store and find one that fits!
Posted on Sep 07, 2010
SOURCE: My problem is stripped out teeth on focuser rack
Contact Meade customer service here:
http://www.meade.com/support/index.html
You may be able to buy a replacement focuser. If not many telescope retailers sell replacement focusers.
Posted on Sep 15, 2010
SOURCE: stripped out adjustment for l-r on red dot finder scope, need parts
Sorry no parts-- these are very LOW cost-- just buy another one.
Orion sells these:
Posted on Jan 18, 2012
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
I've lost restore down in Word. How can I get it back?
if you are referring to microsoft word
Microsoft Word is one of the most widely used text editors in the business world today.
Using Word, you occasionally experience glitches like missing Menu items.
You open Word and while preparing your document realize the Menu item you want to use has magically disappeared.
You can restore it easily.
There are ways to restore lost Menu items in Microsoft Word.
Check your Menu to confirm the button you are looking for is really missing.
Microsoft Word is intuitive and continually adjusts to show the options you choose most often.
Click the double arrow near the bottom of the Menu items to reveal the hidden options.
Click the Menu item you are looking for.
Use that Menu item often and Word will place it in your Menu for easy access.
Replace the missing Menu item in Microsoft Word. Click Tools - Customize.
Select the Commands tab.
Click Rearrange Commands.
Add the Menu item you lost in Microsoft Word.
Select the Menu bar at the top.
Use the drop down menu to select File. Open Controls.
Highlight the Menu item under the File menu and click the Add button.
Select File under Categories. Open Commands and select desired button.
Click Ok.
Word will reveal a preview of the File menu including your changes.
Select the desired Menu item.
Click Add.
To adjust the position of the Menu item you added.
Click Move Up or Move Down.
Continue to adjust them until you achieve your desired results.
Click Close to close the window.
Click File, Exit to close Microsoft Word.
hope this helps
Oct 14, 2012 | ASUS P5PE-VM Motherboard
Chain is off and I am not sure how to get the adjusting screw in
You don't need the adjusting screw, if it is missing, you can still run the saw. Get the chain straightened out on the blade, with the cover on if you can, keep the cover bolt loose, put the blade in a vise, pull on the saw and tighten the cover bolt at the same time, make sure the chain moves, as long as it is not dangling down real loose, you should be all set. My adj screw bit the dust years ago, so did the safety bar. Still works great.
Feb 20, 2010 | Remington Electric Chain Saw
Unable to find place to buy chain adjuster.
Lou
I have a Remington 16" (107625-01)
The nib broke off of the block adjustment and it was bent anyway.
Where did you find item 26 and 27 above?
Thanks Daryl
Jan 29, 2010 | Remington Electric Chain Saw
How do I adjust the screen geometry?
Sharp
Important !
After you get to the item that needs adjusting
Write down the original setting
just in case you have to go back.
1. TV unplugged
2. Press and hold the'Vol down' and 'channel up'
3. While holding the buttons, plug in the TV.
You are now in the Adjustment mode
You will be presented with a category menu containing.
Deflection
Signal
Feature
Fix Value
EEPROM
4. Use the 'Channel up'or"Channel dwn' to select the category.
note:Not all models will have 5 categories, some will jump to the 'Signal' category.
5. Use the 'Volume up' to enter the category.
6. Use Channel up and down select the item to be adjusted.
7. Write down the old value of the item before changing.
8. Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Data sheets are available for most models. These sheets list a description for each
item as well as data range and typical settings for your model. If your setting is
substantially different than the sheet then you may be developing a problem.
you want to go into deflection mode and look for pincushion items i.e pin amp,bow etc. AND don`t forget to write down original values
Nov 01, 2009 | Sharp 27F543 TV
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
WD-52327 Lamp hour indicator.
Found this in another forum. So apologies if there are any innacuracies. service code
menu-5-7-5-7
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
menu-5-7-7-0
Nov 07, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Meade TeleStar 60AZ-A Telescope Logo
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
